Off-road app won’t load
DKM
Duane
SE Texas
2024 Wrangler Rubicon
Just after buying a new 2024 Rubicon
Off-road app won’t load.
Dealer did a “Hard Reset” the app worked for two days, now nothing.
How does one fix this?
Thanks for all the replies. I have contacted Uconnect and I'm waiting for tech support to return my call. Customer Service gave a case number. I was told tech support would contact me in 24-48hrs. Where would I find what software version I have?
Thanks again for the help.
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
I would take it back to the dealer or I guess you could try another reset.
nU7OuxIx
Chicago
Dumb question, but are you in 4wd?
I'm pretty sure he doesn't need to be in 4wd to get the offroad apps to work. I know when you put it in "off road+" mode or maybe even 4l, it will pop up.
I think the app is junk. I've had it hang up more than a few times while it loads. If it happens, I just go back to the main menu app area and start it up again.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Ya, I couldnt remember on my 21 so I went and checked.
In 2WD, first push does nothing, subsequent pushes bring up the below message on dash.
Jeep Wrangler JL Off-road app won’t load 1000010748
NULL POINTER
Carmine
Free state of Florida, NW of JAX
2024 Gladiator Rubicon X, '19 VetteZ06 7spdVert,4
Old Fart
Off Road Pages or the Off Road Pages Plus trial pages not working? (Trail Off Road and Trail logging apps). Mine has the ORP, but the ORP + Trial apps disappeared after two failed over the air updates this past weekend. I have a case going with Uconnect to try and get the ORP+ pages back for me. One of the people I spoke with from Uconnect said that the update resulted in a lot of people losing the Off Road Pages app, but mine was the first he had heard of the Off Road Pages Plus Trial subscription disappearing. OP, maybe try a call to the Uconnect 800 number since the dealer could not get you going.
Note: the Off Road Pages Plus Trial is head unit software and the vehicle does not need to be in 4WD for them to work. The Off Road + red button does need to be in 4WD to work. Two different things.
NULL POINTER
Carmine
Old Fart
OP has a 2024 Rubicon, so he should have both the off road pages and the off road pages plus trial subscription app which is new for 2024 if he activated his trials. An OTA was pushed out recently so he should already have the latest software unless the update failed like mine did twice. He already went to the dealer and it sounds like the dealer was not successful. As an aside, my 2018 JLUR had the ORP and they would disappear sometimes and then come back an hour or so later.
Dyolfknip74
2021 JLU Rubicon
Ok. My work here is done then. Lol.
nU7OuxIx
Chicago
What's the difference between the "off road pages" and "off road pages plus"?
I have a 2021 and I have the offroad app (whatever it's called), that pops up a couple of gauges and if you're in H, L, sway bar and axle lock status.
I also have the "off road +" button that modifies the shift points so it's easier to drive in sand or other terrains.
The "off road+" button requires 4wd first. I'm about 95% sure that the "off road app" (gauges and stuff) works in 2wd but requires a rubicon.
NULL POINTER
Carmine
Old Fart
Correct, you must be in 4WD to use that Off Rod + button. Off Road Pages on the head unit does not require you to be in 4WD. Off-Road Pages + is trial software new in 2024. Totally different from the Off Road + button.
Off-Road Pages+ : Trial
Trial expires on 08/08/2026
Discover new adventures and capture the experience
The Off-Road Pages+↓ package integrates Adventure Guides and GPS Trail Logs right into your Uconnect system, for seamless off-road navigation. With detailed trail guides from Trails Offroad, you can find adventure suited to your comfort level, from casual drives to intense rock crawling.
Download guides for offline use, and rely on GPS Trail Logs for real-time trail maps, track recording, and waypoint marking. Enjoy access to over 200 detailed guides, including every Badge of Honor trail, and review your data right in the Uconnect system.
Unlock the full catalog of 3000+ trail guides when you upgrade to the annual Off-Road Pages+ : All-Access membership↓
mad_hungarian
JLU
Ok, I had everything ready to go do the Rimrocker, offline map downloaded on the head unit. When I got to the trail head to start, all of a sudden my Off-road Adventures app won’t load AND my gps trail logs wouldn’t either. I made it to Moab but situation is the same, neither app loads. I did the soft reset a couple times no dice. Super ticked off. That was one trip that I really needed it on AND wanted to record it with all the pitch and roll and performance data. 🤬
