Jondrew
- Bob
- Dec 3, 2018
- Central Fl
- 2018 Rubicon
Somewhere down my list of mods for my Rubi will be the OEM Aux switch install. Looks relatively easy although it requires pulling a lot of trim panels, passing wires thru the firewall, re-pinning a connector and finally either a reflash from the dealer to activate or use of a Tazer. I’m sure someone has linked this video before, but it seems pretty comprehensive so I’ll link it here.
My only suggested change would be to pull the entire fender instead of cutting the inner fender wall rivets.
Even if you are not planning on adding the Aux switches this video is pretty good because it shows where to pop thru the firewall into the cabin and how to pop out a lot of the dash panels.
