HawkeyeJL
Jim
Iowa
2025 JLU Willys w/Xtreme Recon
Was it requesting an update that was not downloading, or were you just checking to see if it needed updates?
When I try doing it through the App it goes through the whole process then gives me a message that says “remove device from vehicle, plug back in and restart the app to finish update”. When I do it, nothing happens. And when I plug it into my computer to try and use the downloader on the computer, it won’t even find my flashcal
Mike@Powerteq
Mike@Powerteq
Summit Sponsor (Level 3)
Sanford FL
www.superchips.com
16 JK, 21 JL 3.6L M6, 22 Wagoneer 3.0TT
Senior Product Manager – Domestic Tuning at Holley
OK, it sounds like you are asking it to check for updates, that should not be necessary.
The dongle does not update on a PC, if it needs an update for the dongle, it will request it through the phone app.
Have you tried entering the menus to access the features and options while connected to the vehicle?
HawkeyeJL
Jim
Iowa
Yes, but it only stays connected to the app for about 5 min, then it won’t connect again unless I shut the vehicle off and restart it
When I search for updates it tells me there are 70, and it goes through all of downloading them then gives me the mesaage I said earlier about removing , plugging back in and restarting the app
Mike@Powerteq
Mike@Powerteq
Sanford FL
www.superchips.com
Thats certainly not normal behavior. I've shared this with our team and it snot something they have seen. please give our guys a call and we'll troubleshoot it with you and replace the dongle if needed.
407-585-7000
Thanks
Tr4ckD4ys
NY
2025 Jeep Wrangler Rubicon Xtreme 35-inch 2-door, '41 Green
Tech
We've re-engineered the Flashcal+ in an effort to provide the ultimate Jeep feature and options control device! The new mobile dongle and iOS/Android app provides all the control you could ever want, with the option to upgrade to full performance tuning for 07-14 JK models if desired!
  • Single part number (SC-MOD) for all 2007-2025 JK/JL/JT
  • Coverage includes 3.8, 3.6, 2.0, 4xe, 6.4 and 3.0 Diesel applications!
  • 07-14 JK can upgrade to Flashpaq tuning from within the app for improved power and performance
  • NEW - 2015+ Flashpaq upgrades are now available! Upgrade includes the PCM swap!
  • Tons of features and options control!
  • Throttle boost upgrade available for in-app throttle control!
  • Tire size, gear ratio, lighting configs, DRL locations, off-road functions, and so much more!
At $175.95, its THE BEST value in Jeep options control. Check it out on our website here:
https://www.holley.com/products/tun...lashcal_plus_wireless_calibrator/parts/SC-MOD
How is it looking on MY2024 performance options and transmission adaptations? Will this be available via the Flashcal+ in the near future?
Mike@Powerteq
Mike@Powerteq
Sanford FL
www.superchips.com
Working to add GPECV support to add tuning upgrades there for sure.
TxJeepers
2025 JLUR '41
Anyone seen any Black Friday deals on these?
AA_Jeeper
Adam
Allentown, PA
2018 Jeep Wrangler JL, 2025 Jeep Grand Cherokee, 2012 Jeep Grand Cherokee WK2
Mechanical Engineer
Does recalibrating for tire size also adjust transmission shift points? Also, are there any available Android Auto apps that can display gauges and information on the center screen? 2018 JL here.
Mike@Powerteq
Mike@Powerteq
Sanford FL
www.superchips.com
it doesnt recalibrate anything, but since the pcm and tcm know whats going on, its able to command shifts properly.
I have seen users enable the app through Android Auto or CarPlay, but I am not sure what they were using to do so.
AA_Jeeper
Adam
Allentown, PA
Mechanical Engineer
@Mike@Powerteq Got mine installed last night. The updates were pretty long and unstable, had to restart many times.
Now that it's working, the connection is very slow and unstable... it seemingly drops bluetooth connection randomly- sometimes when switching away from the app, sometimes when going between screens, sometimes giving an error when loading the Crawl page. Sometimes I have to close the app, restart, and it will take 30-60 seconds and reconnect. Other times I have to close the app, unplug the OBD connector, replug it in, restart app.
Are you guys aware of this and working on it?
Mike@Powerteq
Mike@Powerteq
Sanford FL
www.superchips.com
We've seen some bluetooth connectivity issues, and its mostly a matter of optimizing something in the app for the specific phone the end user has in hand. If you havent, please submit the bug report from within the app so the team can see whats happening and make sure its on their list to improve.
Thanks!
AA_Jeeper
Adam
Allentown, PA
Mechanical Engineer
Thanks!
I hit the submit a bug report and it says that logs were sent. It does not let me state what the problem is though. I've taken some screenshots along the way.
Mike@Powerteq
Mike@Powerteq
Sanford FL
www.superchips.com
That's perfect, we'll see the errors in the logs.
AA_Jeeper
Adam
Allentown, PA
Mechanical Engineer
Thanks. Will I get a response of some kind if there's a setting I have to change? This is pretty annoying.
Mike@Powerteq
Mike@Powerteq
Sanford FL
www.superchips.com
Not necessarily, they'll push fixes in the phone app or on our server to resolve it. If you call or email, they'll make a case and inform you as soon as the fix is ready.
407-585-7000 or [email protected]
Thanks
