Mike@Powerteq
Mike@Powerteq
Summit Sponsor (Level 3)
Sanford FL
www.superchips.com
16 JK, 21 JL 3.6L M6, 22 Wagoneer 3.0TT
Senior Product Manager – Domestic Tuning at Holley
Does it have a feature for FAD delete?
For the fun control (available with tuning), does PCM need to be swapped for tuning to work?
"and 15+ JK/JL/JT with a PCM swap toward the end of October. "
I believe FAD is there, let me confirm.
As for fan control, it only requires a pcm swap for 15+ models, which should be available toward the end of next month.
Mike@Powerteq
Mike@Powerteq
Sanford FL
www.superchips.com
where do I find this on the website??
I updated all the website stuff this morning, but it takes a minute to sync and go live.
Its 100% there and ready, we've had a few 2025 guys who had the product in hand use it on their vehicles today ;)
Nokones
Kenny
Sun City West, AZ
23 Rubi, 21 Silverado, 13 Grand Sport, Cayman GTS,
Unemployed For The Rest Of My Life from a career of spreading love, cheer, and joy to lots of special individuals that were asking for attention..
Finally, you can disconnect the Front Swaybar in 2-Wheel Drive with the new FlashCal Plus. Although, I haven't had a chance to take it for a spin to see if the swaybar will reconnect on its own at a specific speed like it does when in 4-wheel drive.
HawkeyeJL
Jim
Iowa
2025 JLU Willys w/Xtreme Recon
Do you get any throttle control on the 2025’s? Also, does this do anything to kill the ESS or do I still have to switch it off every time I start it
Nokones
Kenny
Sun City West, AZ
Finally got a chance to test it.
When you're in 2-wheel drive and disconnect the swaybar, there is no max speed that will reconnect the swaybar. Works very well for me. It was well worth the wait (10 months) for Holley to produce the new and improved FlashCal Plus for my 23 Wrangler Rubi 3.6L eTorque 2 Dr. with the Auto Tranny.
Mike@Powerteq
Mike@Powerteq
Sanford FL
www.superchips.com
no throttle control for the 25s until we can provide flash tuning for them. You can use FC+ to recall the last ESS settings, meaning you turn it off once, and as long as the FC+ stays plugged in, ESS stays off ;)
Cips
Anthony
Bucks County PA
2021 Wrangler Unlimited Willys
Sales
For the most part. Mine forgets about 5-10% of the time.
Mike@Powerteq
Mike@Powerteq
Sanford FL
www.superchips.com
HawkeyeJL
Jim
Iowa
Ok, so either I’m doing something wrong, or something isn’t working right. I did the security bypass, plugged the unit into my OBDII, downloaded the app, my jeep and the unit sync’d, but any time I try to do anything, it says it’s not connected via Bluetooth, and when I try to get it to connect, the little green circle just spins and spins and spins
Mike@Powerteq
Mike@Powerteq
Sanford FL
www.superchips.com
If you haven't already, please submit a support request through the app so we can see whats going on.
Give our team a quick call at 407-585-7000 and I'm sure they'll get it sorted out asap.
HawkeyeJL
Jim
Iowa
I finally got it to connect after unplugging and plugging back in about a dozen times. I’m still currently less than impressed. As of today, I’ve attempted to update the software via the app and cellular multiple times, every time it takes about 5 min, then after downloading all the software it gives me a message that says “to complete update, close app, disconnect device, reconnect and open the app”. I do this, and the process starts all over again. Pretty frustrating. It also does not remember to keep my ESS off. The tire size wizard was awesome, once I got it to work.. however after I changed the tire size I got DTC’s for front collision warning and electronic throttle control for about a day.
My current biggest issue is that it connects to the app when I first start the vehicle, then after about 5 min, they disconnect and I can never get the app to find the device again without cycling ignition
Nokones
Kenny
Sun City West, AZ
Are you using the new and improved module?
I have the new and improved module that I received about three weeks ago and it works perfectly on my 23 Wrangler Rubi 3.6L eTorque 2 Dr Auto Tranny. My FlashCal Plus module is working perfectly. My speed is matched to GPS speed, the swaybar stays disconnected in 2 WD, and I don't have any problem with the Bluetooth connection.
The only thing that I haven't tried is the start stop feature. I've been using the Auto Stop Start Eliminator harness and I just been kinda lazy in removing thd harness to try out the FlashCal Plus.
I'll give it a try one of these days with the FlashCal.
I am perfectly happy with the new module.
HawkeyeJL
Jim
Iowa
I’d imagine as I just purchased it a week ago, as soon as they announced 2025 capabilities
