Introducing the new Superchips Flashcal+
Mike@Powerteq
Summit Sponsor (Level 3)
Sanford FL
www.superchips.com
16 JK, 21 JL 3.6L M6, 22 Wagoneer 3.0TT
Senior Product Manager – Domestic Tuning at Holley
Superchips is pleased to announce our all new, mobile Flashcal+ device. This app based options device offers all the control you are after on your JK, JL or JT. With innovative new features like the Tire Size Wizard and standards like TPMS adjustment, it offers something for everyone. Devices are in stock and available now. Click the link to learn more!
https://superchips.com/flashcal-flashcal-plus-jeep-newest-device-wireless/
JK Features:
  • Corrects speedometer for tire upgrades between 26”- 42”, using GPS-powered Tire Size Wizard or by measured height
  • Speedometer recalibration for axle gear and T-case ratio, 2.73-5.38:1
  • Axle Lock Rear w/ T-case in 4-Hi & 4-Low (CRAWL Screen, JK Rubicon only)
  • Axle Lock Front & Rear w/ T-case in 4-Hi & 4-Low (CRAWL Screen, 3.8L JK Rubicon only)
  • Engine idle up for winching, temporarily with CRAWL Screen, 500-2000 RPM
  • Daytime Running Light Location: Halo, Fender, Fog, High, Low, Turn Signal
  • Daytime running light Enable/Disable
  • One touch lane change
  • TPMS Disable, while using CRAWL Screen or completely for use with aftermarket wheels
  • TPMS Threshold adjust 22-56 psi.
JL/JT Features:
  • Sway Bar Disconnect in 2Hi, up to 25 MPH (CRAWL Screen, Rubicon only)
  • Line Lock- holds brakes on front tires only
  • Rock Lock- holds all 4 wheels with brakes for crawling
  • Axle Gear Calibration: 2.73 – 5.38:1
  • Tire Size Calibration by height: 26” – 40”
  • Transfer Case Gear ratio calibration: 2.72 – 5.00:1
  • TPMS Warning Threshold adjust: 22–56 psi.
  • TPMS Disable, for aftermarket wheels and no sensors
  • TPMS Off/On (Crawl Screen)
  • Daytime Running Lights Operation: Always On, Selectable, or No DRL
  • DRL Location Selector: Fog, Fender, Running, High, Low, Turn, or No DRL
  • DRL Dropout Disable, keeps DRL on when using turn signal
  • Fog Lights Dropout Disable, for simultaneous use of high beams and fog lights
  • Halo Lights Enable or Disable
  • One Touch Lane Change Enable
  • Dashboard Splash Screen select: Rubicon, Sahara, Sport
  • Seat Belt Minder Disable, stops chime
  • Travel Link Weather Warning Disable
  • Lighting Config, selects Standard or LED: Front Turn, Tail Lights, 3rd Brake Light
  • Auto Start/Stop Disable
  • Auxiliary Switches Enable, to add extra factory Aux switches*
  • Blind Spot Detection Disable, or Enable to add if not equipped*
  • Factory Fog Light Switch Enable, adds controls if not equipped*
  • Towing Package Enable, adds controls if not originally equipped*
  • Backup Camera Disable, or Enable adds if not originally equipped (2018-2020 JL Only) *
  • Cargo Camera Disable or Enable adds if not originally equipped (2018-2020 JL Only) *
  • Electronic Steering Pump Disable, for conversion to hydraulic system*
  • Axle Lockers Disable Rear Only, OR Front and Rear for conversion to manual*
  • Axle Lock Rear OR Front and Rear w/ T-case in 4-Hi & 4-Low (CRAWL Screen, Rubicon Only)
    *Our devices reconfigure vehicle controls for this associated change, but additional OEM or aftermarket parts are required to complete the conversion.
Mike@Powerteq
Mike@Powerteq
Sanford FL
www.superchips.com
The app can be downloaded for Android or iPhone and used in Demo mode for anyone that may want to take a look.
Mike@Powerteq
Mike@Powerteq
Sanford FL
www.superchips.com
Does this give you access to short and long term fuel trim via the gauges feature?
Yes, STFTB1/B2 and LTFTB1/B2 are all available.
Jeep Wrangler JL Introducing the new Superchips Flashcal+ Fuel_Pids
Kindapointless
2022 rubicon 2dr
Parts guy for mini/bmw
Gpec 5 on the 2022s? Seems most things don't work for them
Mike@Powerteq
Mike@Powerteq
Sanford FL
www.superchips.com
Not for this device, no. Hopefully we’ll have some good news on the regular flashcal regarding gpec5 support soon.
Thanks
Mike@Powerteq
Mike@Powerteq
Sanford FL
www.superchips.com
FYI, the standard Flashcal 3571-JL/3571-JT models will work on the GPEC5 based vehicles :)
