snapper692
If I had to pick a word to describe this right now, that word would be 'clunky' (Im upgrading this word to 'disaster'....or better yet, 'nightmare'). Feels more like a beta (alpha) release...And I'll tell you why.
In general:
@MikeM@Superchips
In general:
- Some features have to be done with the engine running, some without.
- Some features that have to be changed with the engine running require you to restart the engine for them to take effect.
- You have no idea what the requirements are till you try and save them.
- Can't clear DTCs with the engine running. You can pull them with the engine running, but not clear them. Maybe that's normal for jeep?
- After the first couple changes I made, the dash seemed to shut down normally after exiting the vehicle. After making a few more, it became rather delayed. I gave up after waiting 5 min and just removed the module. Haven't checked the shutdown time yet but will shortly. If it changes with it removed, Ill update this post.
- Clunky. If you're using the analog gauges, you should be able to view 2 at a time without scrolling. Gauges need to be closer together.
- If using digital gauges, you should be able to see 3 items. This is easily doing as this is just a spacing issue.
- Not enough supported PIDs! There shouldn't be an issue supporting the basics, like oil temp, trans temp or engine timing. These need to be supported!
- Super clunky! You shouldn't have to hit 'ok' 4 times to lock an axle!
- If you want to lock the front axle (after the rear is already locked) you have to unlock the rear, then lock them both toghether....again with clicking 'ok' 4 times (5, technically). This HAS to change.
- Same goes for the sway bar...Having to click 'ok' 4 time is too much.
- You're already providing visual updates when changing things, no need to acknowledge everything.....multiple times.
- Need to add the ability to disable traction control, preferably from the crawl screen.
- Need the ability to activate the rear camera at any time or any speed while in drive.
- Add the ability to enable the proximity sensor module. That's a popular add on that steers a lot of people to the Tazer.
- Need a 'reset all' feature. So far, I have to reset every option manually to go back to stock.
- You have to get rid of having to send this in to unmarry from a vehicle. This is so 20 years ago...lol.
@MikeM@Superchips
