alphawolff
- Jul 31, 2023
- california
- 2021 JLU
The ESS requires an SOC over 65% to function. Lower than this and you will get a "Battery charging" message in the EVIC. The vehicle will continue to start and function fine until the batteries begin to fail completely. It will be sudden with no warning. You will go out one morning and it won't start. You only get a S/S warning light if the aux battery outright fails the voltage load test upon first crank. It takes awhile to get to the point. You may also find it stalls out at a red light blowing the z-case fuse, which is very common.Let me preface by saying that I don't care that the ESS isn't working, and have done zero troubleshooting with no intention of really digging into it, but am curious to see if anyone might have experienced the same "issue".
About 7 or 8 months ago I noticed that the ESS on my 18 JLUR wasn't working. The only dash warning is the "ESS not ready. Battery charging" in the message center. No other warning lights are lit up. Charging system is consistently in the 13.8 to 14.5 range. No other issues with electrical system, no starting/cranking issues. Both batteries are about 2 years old. Maybe 3. I forget exactly.
The general consensus seems to be that my aux battery is toast and should have killed my main battery and left me (or even worse - my wife) stranded somewhere by now, but it has not. I'd also expect that I'd have a warning light or two in addition to the message center notification.
So I guess what I'm getting at is, is it common for ESS to quit with no dash lights illuminated, no other electrical issues and still be up and running months later?
Replace both batteries before you are indeed left stranded.
