New Engine Install - Rough start then Stalls
roaniecowpony
Retired Engineer
I have just got my 3.6 engine from a 2024 Gladiator installed and to the point of trying to start it. It cranks long and then when it starts it's very rough and stalls after a few seconds.
The company I bought the engine from said it was removed from a Gladiator with 160 miles on it, for a Hemi conversion. It appears as new. Even the oil was new. They told me the only thing I needed to do for installation in my 2018 JL was to change the Oil pressure sending unit under the intake manifold and put my engine harness on it. I installed my 2018 sender and the 2018 harness.
I haven't done a crank position sensor relearn nor a throttle position sensor relearn, since both require you to start the engine, which seems to be a problem for me.
So, thinking the old engine's throttle body might be recognized by the PCM, I quickly installed it. No difference at all.
Any ideas on what it may be? I'm leaning toward some sensor not being connected. But I haven't found one.
Can a crank relearn be done without running the engine?
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
Double check any timing sensors. You may want to check them and make sure that they still use the same part number.
roaniecowpony
roaniecowpony
Retired Engineer
My old engine is still at my friend's warehouse. I want to pull the sensors. Not sure if anyone is there over the weekend. If so, maybe swap cam and crank sensors.
Stetson
Salt Lake City
2019 JL Sahara, 2023 392 Rubicon, 2020 GMC 3500 Denali
Project Manager
Can you tell if it is getting fuel? Rough idle and then stall sounds like not enough fuel. I haven’t tinkered with a 3.6 much, can you pull a injector and see if it is sending fuel at start?
cosmokenney
Cosmo
Loyalton, CA
2019 JLR (2-door)
At this point I'd also be taking a close look at all the connectors to make sure no pins are bent. Especially the ECU (or whatever its called in the JL).
roaniecowpony
roaniecowpony
Retired Engineer
Just did a comparison of all the sensors online. All the same part numbers, a few have letter suffix revisions. But that shouldn't be a deal breaker.
roaniecowpony
roaniecowpony
Retired Engineer
Yeah that crossed my mind. More so, a pushed back pin. I'll check it this morning.
roaniecowpony
roaniecowpony
Retired Engineer
It's getting some fuel. At least enough to smell it. But fuel supply has crossed my mind. I have the old engine's intake manifolds here, which have the injectors still in them. Maybe pull an injector from the old and hook a connector to it on the new and see if I get fuel spray. It is getting something. My thoughts are it could be low pressure by the way it's acting. Maybe i can find fuel pressure in JSCAN and see.
Stetson
Salt Lake City
Project Manager
That is my initial thought based on what it is doing. Doesn’t seem to be getting enough fuel. Other thing to also look at is the security system / alarm is a fuel shut off. If for some reason that is triggering you might get the same symptoms
roaniecowpony
roaniecowpony
Retired Engineer
I noted it now, won't crank and the Unconnect display asks for a security code. Not sure where to go next.
Stetson
Salt Lake City
Project Manager
Yep. That’s the issue. Do you have your old ecu? Might try that. Have to get around this security issue to get it to start .
roaniecowpony
roaniecowpony
Retired Engineer
Im using the old ecu and engineharness. The 2024 ecu's aren't compatible with the old vehicles. All the sensors are the same part number.
I recall some people having trouble with the green canbus block.
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
I'm not sure why you are getting a security problem when using your old ecu and engine harness. I can't think of anything else on the engine that would communicate an individual id or anything.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Can you pull codes from all modules? Sounds like theft prevent but might not be.
The Uconnect asking for a code generally only happens with stupid battery problems. You kill the aux battery?
alphawolff
california
2021 JLU
If the uconnect display is asking for a security code then your PCM is either offline or you installed the PCM from the donor JT for some reason.
Make sure you're using your stock PCM and it's properly plugged in. I strongly suspect you either damaged the pins or didn't plug the engine harness in properly.
