mwilk012
It sounds like that is the problem. No comms with the PCM.In addition to the previous fuse and relay checks, pcm connector check, and PDC connector check, I ran the Ignition Off Draw (IOD) parasitic test. After waiting for the modules to shut down, the system only had 12 ma of residual draw, which is well within the 50 ma limit. Passed.
The Power Control Relay is not stuck in the open position. Normal for the PCR is closed (connected). Passed.
I put in my SGW bypass harness and hooked up the Autel MP808S with the ignition in the "ON" position, engine not running. Tried to get it to read the VIN and that failed. I manually entered the VIN and it confirmed the make/model/year correctly. When I had it check for codes it said there was no communication with the PCM. Fail.
I installed the wireless BT bridge in the SGW bypass harness and opened JSCAN. Ignition "ON" engine not running, cleared codes, JSCAN gave me a U0100 code "lost communication with engine control module/power control module. Fail.
two weeks of chasing tails when the problem was obvious from the start. I know communication faults is well outside the normal scope of standard DIY'ers but it's an important part of modern diagnosis.
