Need help, installing adjustable LCA
Eischman
Hortonville, WI
2021 Rubicon Unlimited
Help me understand this before I tighten the bolts on the first side!
If my stock LCA were 24" and Teraflex says for 2.5 lift that my new ones should be at 24.25" -24.35"
why does the arms go right back on, shouldn't there be some kind of struggle to get the longer arms on??
This is going on a 21 JLUR with 2.5 spacer lift and 35" tires, the caster on the stock arms were 4.7 left and 4.8 right.
Roky
Roky
Because the axle likely moved forward when you took stock arm out. Since your up 2.5” the oem arm pulls the axle back when lifted…..
Eischman
Eischman
Hortonville, WI
Thanks Roky!
Though I'm not disappointed that I didn't have a struggle! :LOL::LOL:
slowcrawlerZJ
Chad
Oklahoma City
2019 JLUR, 1982 CJ7, 2018 WK
Retired Navy
Exactly! Well said. That’s is the usual circumstance. I have the same set up on my 2019 JLUR. I ended up adding adjustable UCA and changing my castor to 6.1 to decrease any steering wondering and steer bump.
Eischman
Eischman
Hortonville, WI
I'm also hoping that quarter inch is long enough to get the caster up, quarter inch don't seem like much?
limeade
Guy
Reno, NV
Unlike other aspects of life, .25 inches will make a noticeable difference.
slowcrawlerZJ
Chad
Oklahoma City
Retired Navy
Doesn’t seem like like much but you will be surprised at what a few 1/16’s does or a few turns on adjustables effect on the castor
Roky
Roky
You be surprised, although the Mopar lcas are usually only effective up to 2 “. You’ll still feel a difference, but adjustable will work better for 2.5” lift. Also most of the time you get more than advertised lift height…….
Eischman
Eischman
Hortonville, WI
Thats why I spent the extra $100 on adjustable, I just couldn't see spending the $$ and being stuck at one length.
This way my front-end guy can dial it in exactly.
