Most important under armor?
Blues Fan 30
St. Louis
After being offroad for the first time ever and enjoying it we are definitely going again at some point. I will say the trails we were on were nothing super crazy and I got out and scoped many of the lines before actually proceeding. I don't have the budget for a full on skid setup nor do I feel it's worth it with how I intend to offroad. More or less interested in protecting the most likely oopsie underneath. That being said, where am I best spending money? The obvious choice seems to be diff skids as that's the low hanging fruit if you will.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
You already have sliders and bumpers?
Centurion07
'MERICA
2019 Rubicon 2-Dr
Just in case the trail is way worse than you thought...
Jeep Wrangler JL Most important under armor? 1000010601
Based on some advice I got from a trusted forum member, I went with diff skids and skids for the rear LCAs. Part of my decision was based on how much lift I have and my intent to choose my lines carefully vs doing a full send on every obstacle.
Blues Fan 30
Blues Fan 30
St. Louis
Yeah I was just climbing around underneath doing some cleaning and checking things out. I'd agree seems like the rear lcas are also pretty low on the back side. Protecting that area and the shocks back there seems like a pretty good investment as well. Which skids did you go with? I was looking at metalcloak because tbh they look badarse but the diff skids appear to be only for rubis?
Rubi6mt
Nj
2021 JLUR 6mt
In my view the oil pan and the exhaust crossover area are both exposed and will lead to a bad day if you hit hard enough.
those would be my primary focus areas.
Case in point how my skids look over the exhaust over area on a rocky trail and yes I was picking my lines carefully
Jeep Wrangler JL Most important under armor? 20240729_123125
Blues Fan 30
Blues Fan 30
St. Louis
The oil pan definitely seems to be a popular choice as well. I did some searching and most of it is listed for the 3.6 not the 2.0. Not sure if they're interchangeable or not?
Centurion07
'MERICA
2019 Rubicon 2-Dr
I went with Rough Country. Not super gold & sexy, but still heavy steel plates.
Jeep Wrangler JL Most important under armor? 1000010447
Jeep Wrangler JL Most important under armor? 1000010449
Maverick909
I.E.
oil pan/trans skid plate is the most important. followed by rear diff and LCA skids. then i would add the front diff and LCA on the front.. factory fuel tank does just fine. I would also look at a GOOD set of rock sliders. save the money up for sliders. I learned the hard way buying smittybilt slider/steps. was a big waste of 300+ bucks. now the jeep has dented door sill driver and passanger after coming off a rock harder than it looked. Now i have a set of LOD sliders. LOD makes really good stuff and well worth the money
melendez69
Marc
Waxhaw NC
...huh?
Maybe consider the FAD?
Rubi6mt
Nj
2021 JLUR 6mt
Don't think they are interchangeable as they bolt onto the engine mounts.
Mx5red
Paul
San Diego
2020 JTR, 2020 JLUR
What will strand you? Oil pan/transmission lines that the engine skid covers.
Then I’d do diffs. I haven’t seen anybody post pics of a cover getting “peeled” off dragging over a rock, or caving a front cover in, but there are stories of people doing that.
Agree stock gas tank and t case skids work pretty good.
Centurion07
'MERICA
2019 Rubicon 2-Dr
What will strand you? Skid pan/transmission lines that the engine skid covers.
Agreed. I went with diff skids because they're the lowest bits. I'd have to drop on some gnarly stuff after making some sort of bad decision to really hit much else.
I'm not saying it couldn't happen. I just have to be selective on lines and obstacles. The Jeep is my DD, too.
beast40
Cary, NC
2018 JL Rubicon
Has anyone actually damaged a rear Diff? The cover can peel back, so I understand the rear diff cover, but in 20+ years off-roading I've never seen a damaged differential that would require one of the many diaper options now on the market. If anything I would take the additional ground clearance over the protection. Is it for the u-joint protection?
Oil Pan, Tranny/X-fer case, Diff covers would be the first skids I'd recommend. Keep your Jeep as light as possible while protecting the most important items.
Centurion07
'MERICA
2019 Rubicon 2-Dr
Hey now, don't be hatin' on diapers...lol
Blues Fan 30
Blues Fan 30
St. Louis
This was my thought too. After some digging it seems the oil pan/trans line cover more protects from branches or anything like that catching on those components and ripping them out more than crush damage to them. Makes sense to me actually. Leaning towards that plus the rear lca/shock skids.
Does anyone know what budget skids are available for the oil pan? So far the only one I've found for a 24 2.0 is the m.o.r.e. also, needing lca skids compatible with teraflex shock extensions.
