Zandcwhite
- Zach
- Sep 4, 2019
- Patterson, ca
- 2019 jlur
If we are talking stock for stock, unbolting parts doesn't count. I can bolt on a set of 35's on a stock Rubicon in the time it takes to unbolt and bolt the sway bar back on a couple times.Sway bar disconnect? 18mm wrench and ratchet and 2 minutes of your time. Is anyone actually wheeling without disconnecting?
But yeah id take rubi on 33s over willys on 35s any day in terms of capabilities. Unless the willys XR had lockers. those lockers are huuuuge help. Wheeling the open difs on hard trails is not easy at all, requires lots of effort. The lower crawl ratio I can deal with, the sport and willys transfer case has a low enough ratio, with a bit of left foot technique you can get by. Having no lockers require a lot more skill. But id still rather have the lower crawl ratio than not obviously.
Lower crawl ratio makes it easier. But no lockers sometimes means youre gonna have to stack rocks and/or send it and risk body damage sometimes. And in some scenarios, although not very often, youll have to winch.
That rear LSD helps to close the gap a bunch. And in combination with BLD it acts almost like a locker a lot of the times. but the moment you lift a tire it does absolutely nothing. Been there done that. at a minimum you need the rear lsd + front locker + skill to have a chance to match the rubicon capabilities on a sport. Thats just reality.
