Mopar Lift Help on 4xe
Gazelle
Eric
Seattle
JLUR 4xe ordered 11/6/20; delivered 5/13/21
Today I'm attempting my first ever suspension lift installation. Armed with several views of various youtube install videos, I'm forging ahead with the Mopar lift for my 4xe. Unfortunately, I'm stuck at loosening the aft bolts on both front, upper control arms. The 18mm nut is just not turning, and I'm beginning to round the nut.
I've tried both a deep socket with breaker bar & an impact wrench without success. At this point I either need to abort my effort or continue with both aft UCA bolts tight. I'm figuring it will be OK left tight. Image of the offending nut.
How critical is it to loosen both sides of the UCA for this installation?
Jeep Wrangler JL Mopar Lift Help on 4xe 20210704_130925
Roky
Roky
That’s a flag nut, it’s not going to move , you need to be loosening the bolt instead. Loosen from the other side..
hoag4147
Colleyville, TX
2022 JLUR XR
That is a flange nut. Do not put a wrench on that. Loosen the bolt from other side
hoag4147
Colleyville, TX
2022 JLUR XR
Funny. We were typing at same time lol
hoag4147
Colleyville, TX
2022 JLUR XR
Gazelle
Gazelle
Eric
Seattle
Finished up the lift installation and then installed my "37" inch KO2's. Looks good and drives near stock (on road only, so far). Thanks, again, for the quick help on Sunday.
Pics as promised.
Jeep Wrangler JL Mopar Lift Help on 4xe 20210706_214749
Jeep Wrangler JL Mopar Lift Help on 4xe 20210706_214702
Jeep Wrangler JL Mopar Lift Help on 4xe 20210706_201242
New sparentire carrier comes next (and soon).
gato
New England
2021 JLUR
Jeep looks awesome. Congrats on doing the install yourself. I too did my first lift on my JL, and loved doing it.
In my case, I had a hard time loosening the lower control arm bolts. Even a 1,200lbs breakaway torque electrical impact couldn't take it out. Had to use two breaker bars - one pushed by a floor jack :)
Sounds like you had no such issue. I'm glad you didn't spin that flag nut off. I actually spun one of the factory (inside the frame) welded nuts trying to force fit a skid plate and had to use a flag nut to complete the install. Every project must have
hoag4147
Colleyville, TX
2022 JLUR XR
Pics as promised.
Looks great :like:
