using 2" 4xe Mopar lift on 2023 Willys
devster
Charleston, SC
2023 Wrangler Willys
IT Director
I'm assuming using the 2" lift designed for the 4xe will raise a standard ICE Jeep by 3"+ since the 4xe is so much heavier.
Does it introduce any other concerns or are we good to go? Will it be too stiff since the springs are designed for more weight?
Goal: lift + 35" tires. I understand you can use 35" without a lift, but I'd like a little bit of height.
I feel like this has been discussed but searching hasn't returned exactly what I'm trying to find.
Example: https://www.moparonlineparts.com/sku/77072522.html
lindaspins
Linda
Burton, OH
2015 JKU Rubicon Hard Rock
Springs on the 4xe lift are front, back and side to side specific for the weight of the battery and the heavier suspension. You may not end up getting what you think out if it.
devster
devster
Charleston, SC
IT Director
That makes sense. Thanks!
