Mopar 2" lift alternatives
burnyd
Daniel
Pittsburgh
Corvette z06
So I put in a order at my brother in laws dealership roughly 4-6 weeks ago for a 2" lift for my wifes 21 4xe. However, it appears that there is a shortage possibly until spring of 2023 :( I need to get something on the jeep here soon as I have 37" K02's ready to go and the stock tires are doing the traditional cupping unfortunately :(
That being said can anyone recommend a decent lift kit out there for a 2.5"+ for the 4xe that is actually in stock and ready to order? It seems like most tend to like the AEV 2.5" kit. I also have the 1.5" spacer as well to go a long with a kit.
Thanks!
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
Thanks!
Message Marcus at @River City Offroad he will hook you up ??
roaniecowpony
Retired Engineer
Metalcloak.
River City Offroad
Marcus
Dripping Springs, TX
www.RiverCityOffroad.com
2019 JLUR Triple White - RK 3.5" X-Factor Stage 1 / Steer Smarts / Mickey Thompson / Fuel
Owner at River City Offroad
Thanks!
Id be happy to help you look at some options. I’ve lifted a few 4XE now and I can help you choose something to suit your needs as well as something in stock and ready to rip. I carry all of the major brands!
Thanks for the tag @hoag4147!
GrayWolf.Overland
Subash
Maple Ridge, BC, Canada
www.instagram.com
2025 JLU Rubicon (Anvil Gray)
@Clayton Off Road 1.5" Ride-height kit.
Synergy 2" Stage-1 lift kit
Dynatrac Endurosport 2" lift
in order of my personal preference.
TX_Ovrlnd
CStat, TX
'22 Zilver JLURD
freethinker
What psi are your stock tires at? Cupping indicates wheel imbalance, inflation, or it needs an alignment. A dealer should be able to correct that and get you back to proper ride until you find your lift kit.
lowmpg
Ryan
Kent Island, Maryland
2021 Rubicon, 2025 Ram Limited
No issues or regrets at all with AEV 2.5"
Clayton Off Road
Hamden, Ct
Hey there!
If you're looking for a system comparable to the Mopar kit, but that comes with all of the components necessary to maintain proper suspension geometry and ride quality, definitely check out our Ride Right system. This kit features front-upper adjustable control arms so you can perfectly dial in your caster angle, as well as front and rear adjustable track bars to re-center the axles. This is the best entry-level system on the market if you're looking for the best on-road ride quality :like:
https://www.claytonoffroad.com/product/jeep-wrangler-15-ride-right-lift-kit-4dr-2018-jl-jl-4xe
manapiko
Patrick
Lake Serene, WA
2021 Jeep Wrangler
Is Clayton going to be running any black friday/cyber monday deals? I might have to scoop that kit up. I was originally looking at the mopar one, but love all the components in this kit!
rhocking
Rick
IL
2020 Wrangler 2.0T JLU Sport S
Hey there!
I looked at the 2.5" lift kit on your webpage and the parts listed did not include bump stops. Most other kits come with bump stops. Is there a reason most kits have bump stops or spring pads or bump stop extensions but the Clayton kit does not?
Clayton Off Road
Hamden, Ct
We will be, stay tuned!
Dr. RGB
Ryan
Leesport, PA
2025 JL Willys 2-Door
Professor and Shrink
I have the 2.5 Overland + and can attest that mine came with new bump stops. I love my lift kit; the kit is near infinitely adjustable and offers a superior ride.
Clayton Off Road
Hamden, Ct
The Ride Right kit does not come with bump stop extensions as it is intended for somebody looking to lift the vehicle properly to fit a larger set of tires, and primarily plans on keeping the vehicle on road. If you do want to take it off-road a little more often definitely consider adding in the bump stops which can be found in the "related items" tab!
