Metalcloak Bump Stops
h41g
OC, CA
2021 JLUR XR
Hey guys. I noticed my front bump stops are not straight. Passenger side is almost touching the coil. I asked the shop and they said because of the caster setting. Does this seem normal, or anything to be concerned about? Thanks
Jeep Wrangler JL Metalcloak Bump Stops F9EEA8AC-DC52-4F63-8FBE-BE4CBF57880D
Jeep Wrangler JL Metalcloak Bump Stops 59602961-A59D-4523-A6D6-BB979741ACED
Jeep Wrangler JL Metalcloak Bump Stops 43C50D60-8041-4465-8160-8674E0DDF045
Jeep Wrangler JL Metalcloak Bump Stops E3E9CD0A-9B72-44C2-880C-352CA42089C4
firedude
Bret
AZ
2022 Rubicon XR 392 Stingray
Retired firefighter
Not normal at ride height. Check and see if the axle is centered. Measure coil bucket to inside of tire on both sides.
NateCO
Nate
JLUR XR 2.0L '22
I was just looking at the game changer install instructions and it mentioned that those pucks will just compress down as you tighten the bolt on top. Maybe it was tightened too much and is causing the stack to lean to the side?
