measurements for control arms
focofourxfour
Jack
2021 Jeep JLUW
Hey everyone,
i just got a complete set of adjustable control arms (upper/lower/front/rear) and am wondering what measurements they need to be at with a two inch lift. i’ve seen some posts of measurements for the front lowers but am having a tough time finding measurements for all.
Thanks!
Birdcatcher
S
NVA
URJ201, JLUR 392
Try out Clayton Offroad’s website.
I think I saw there somewhere the approx lengths for this stuff based on the lift height.
Will try to find the link if I get time (I had saved it somewhere).
Roky
Roky
Hey everyone,
Thanks!
These are for 2.5, 3.5, and 4.5” lifts, so be careful to read the right ones. The 2.5” settings should work for you…..
Front Track Bar (RK06187HD)
2.5” lift – 34 3/16” 3.5” lift – 34 5/16” 4.5” lift – 34 7/16
Front Lower Control Arms (RK06184B)
2.5” lift heights – 24 1/4“ 3.5” lift heights – 24 5/8” 4.5” lift heights – 24 11/16”
Rear Lower Control Arms (RK06190B)
2.5” lift heights – 20 1/4” 3.5” lift heights – 20 5/16” 4.5” lift heights – 20 3/8”
Rear Track Bar (RK06692B)
2.5” lift (w/ bracket) – 37 9/16” 3.5” lift (w/ bracket) – 37 11/16” 4.5” lift (w/ bracket) – 37 13/16”
Front Upper Control Arms (RK06697)
2.5” lift heights – 20 7/16” 3.5” lift heights – 20 9/16” 4.5” lift heights – 20 5/8”
Rear Upper Control Arms (RK020208B)
2.5” lift heights – 17 9/16” 3.5” lift heights – 17 5/8” 4.5” lift heights – 17 11/16”
SUGGESTED STARTING LENGTHS
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
This should be a sticky in the DIY/Suspension section ??
BDinTX
Dallas, Tx
Regarding accurate measurements, is there a good technique? I assume these lengths are from the center of the bolt hole on each end.
Maybe insert a bolt in each one, measure outer edge distance and subtract width of one bolt?
DLW
Bay Area, CA
2019 Jeep Wrangler JLUR
You could install the bolts and measure outer edge on one side and inner edge on the other, then no subtracting needed.
Also, almost every lift manufacture installation instructions has the CA's lengths stated in them.
somedude922
McFrisco
2021 JLUR, Previous: 1984 CJ7, 1979 CJ7
Be midful these are starting points. My Jeep was anaemic on the caster from the factory. BDinTX had the same lift as me and I was way under on my caster. I now have a MC gamechanger and Roky gave me some numbers, I was still short on my caster. So every Jeep is truly different!
BDinTX
Dallas, Tx
fair point - and as starting measurements, accuracy probably isn't critical.
