Maximum boost pressure?
rickinAZ
Rick
Phoenix
2026 MOAB 392
My Scangauge shows boost pressure topping out at 22.4 lbs, but I read on this forum that the Scangauge readout itself may be the limiting factor. Does anyone know more about this?
GSLSE21B
Fair oaks
2021 jLURD
Stock is 28. Mine was hitting 34.9 and going low on the fuel supply , I have it at 31 now doing some testing
Gorilla57
Chandler AZ
2019 JLUR Mojito
How are you running out of fuel? Isn’t the CP4 the same setup as what’s on the Ford/Chevy/Dodge full sized truck diesels?
GSLSE21B
Fair oaks
2021 jLURD
The derringer is only increasing fuel pressure , it doesn’t change injection timing . It’s turned down to 31 now and working fine .
KNN
K
Maryland
2020 JLU Sport Diesel
How do you adjust boost pressure?
diamondschwin
Tennessee
2019 Bikini Blue JLUR, 2021 Billet Silver JLURD
My SG maxes out at 22.6
not sure if there’s a way to adjust its readout.
rickinAZ
rickinAZ
Rick
Phoenix
2026 MOAB 392
Sorry that I didn't write a follow up. Scangauge took a few tries to get there, but their guys figured it out for me. [my max boost registers 27+ now.]
Try creating this Xgauge:
Boost Pressure (PSI) (Assumes 13.7 PSI Ambient Pressure) (Revised)
TXD: 07E0227056
RXF: C46285703656
RXD: 3010
MTH: 001D00C8ECE8
diamondschwin
Tennessee
TXD: 07E0227056
RXF: C46285703656
RXD: 3010
MTH: 001D00C8ECE8
You are awesome. I’m going to set this up tomorrow AM!
BuffaloBill
Bill
WI
2024 Wrangler 2.0, 2020 wrangler 3.0
TXD: 07E0227056
RXF: C46285703656
RXD: 3010
MTH: 001D00C8ECE8
Do you mean 14.7 psi ambient?
rickinAZ
rickinAZ
Rick
Phoenix
2026 MOAB 392
That was a cut/paste of an email from Scangauge. That said, standard atmospheric pressure is 14.7 psi - so, yes, you are correct. I believe that it's just a typo, as opposed to something that changes the integrity of the setting..
GSLSE21B
Fair oaks
2021 jLURD
Stock boost map
WXman
Central Kentucky
I've got to try that. My boost tops out at 22.7 PSI on the Scan Guage for the Ram and Jeep both.
diamondschwin
Tennessee
It works… I’ve seen mine up around 28 or so… haven’t kept too close of an eye on it but before it seemed like it would hit the 22.6 or so and then just stick there even as you continued adding throttle.
