gek
Are you saying the added resistance depletes/disperses the lube quicker or am I reading that wrong? Or are you just saying it is potentially causing pushrod deflection. The deflection of the pushrods makes sense in that scenario. Sticking throwout and deflecting pushrods could definitely make for engagement issues and possibly increase slippage creating more dust.I'm an outside observer to this issue, but I did help replace cylinders and bleed them 6 ways to Sunday and my background is engineering. I've also installed an ACT clutch on the OP's latest engine when we installed it, as well as having driven her Jeep with and without the issue. So, I guess I've been around the issue quite a bit and I'm familiar with the hardware.
I think we all can agree the pedal pressure of the ACT clutch is heavier than the OEM. I think this is the root of the issues that eventually develop. The initial installation with the proper lube on the throwout bearing works fine until the grease is depleted/dispersed/contaminated with dust. Then, I believe, the friction, on the sliding portion of the throwout bearing, goes up and the problem begins. The creaking noise is friction, which I believe is the plastic of the throwout bearing sliding and sticking on the shift fork and the snout of the transmission. The master and slave cylinders have plastic pushrods, IIRC. I think these pushrods deflect under the added pressure that occurs when the grease on the throwout bearing gives up.
Some potential solutions might be:
- a throwout bearing with lower friction material where it contacts the shift fork and snout of the transmission.
- replacing the master and slave pushrods with metal pushrods.
Minus the potential pushrod deflection with less pressure needing applied, I do wonder what lube they use on it from the factory. I know several manuals that went 50-100k on the original clutch without any engagement/shifting issues. If lube contamination/depletion is our main issue then I would think it would happen to stock vehicles more unless the lube was performing so much better.
