Major pulling after lift HELP!
blakejordan
blakejordan
Blake
South Florida
2021 Wrangler JLU 4XE Rubicon
new shocks are on! jeep still is driving like a crazy girl at highway speeds. wonders like no other and constantly having to fight the steering wheel. I feel like ive done everything!
Craigb
Craig
Houston
2018 JLU
Did you get the caster up around 6 degrees?
Craigb
Craig
Houston
2018 JLU
Have you ever tried to ride a bicycle with the handle bars turned 180 degrees (this is negative caster) you will fall right over and have no stability.
OnlyOne
Northwestern New Mexico
2021 Sport S Diesel on 37s
Joe kenzo
2018 wrangler jl
That’s not an alignment issue , it’s steering issue , steering box has a gap and causing that , not even jeep have found a solution for that , still waiting for them to fix it , don’t waist your time and go to the dealership , they don’t know shit and will tell you everything is fine
DickZip
S/w Florida
2018 Jeep Jl Rubicon
I have the skyjacker 2.5 with the black max shocks. The shocks are junk, replaced them with rubiconexpress shocks, wow what a difference. I also replaced the OEM steering stabilizer. Went with the RC but it failed after 5,000 miles replaced it with the King. With those changes my Jeep rides and steers like it should. Let’s see how long that lasts...
Jammer
Ft worth
Bright white JL Rubicon
Is that at high speeds or any speeds ? I have the Mopar lift and have the dealer put it on for me because they were cheaper than anyone else and this dealer has an awesome aftermarket Department that does all kinds of things. they put on anything you want after market or Mopar stuff the guy that runs it is very good I have no problems I'm very happy
DickZip
S/w Florida
I have evo LCA
