Magnetic drain plug for early warning engine failure
bd100
USA Midwest
JT
Just wondering if a magnetic drain plug might realistically show accumulated fine metal if the cams start to go.
And if it'd be worth it to catch the metal which might otherwise flow all over the engine.
But there is also an oil filter, so perhaps this idea won't work.
JustDucky
2016 Boxster GTS (Just Sold), 2017 Macan GTS, 2025 Rubicon X (4/12/2025)
Happily Retired !
I mean, it can't hurt. Pulling the oil filter apart to look for bits of metal in the paper element wouldn't be a bad idea either. Neither would it be a bad idea to send oil off for analysis at each oil change. The last idea though is probably the most telling of engine health.
jadmt
jeff
montana
yup can't hurt but probably better to check the inside filter pleats which fortunately on the 3.6 filter is super easy...and as was also stated send in an oil sample once and awhile..
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
I think so. So far mine looks great after 4k oil change.
Jeep Wrangler JL Magnetic drain plug for early warning engine failure oil drain plug
