Low tire pressure indicator light
Willys.JLU.2021
Lance
2021 Jeep Wrangler willys sport jlu
Was curious if any JL owner has seen this issue recently. So I've owned my 21 JL since September 2021. The whole time until now I would only get a low tire pressure warning light when a tires pressure went below 30. I keep my tire pressures around 34 to 35. So today im driving down the road and I see the low tire pressure light illuminated and in the tire pressure display it says all four tires are low and increase pressure to 37 . I am wondering if Jeep made a software update and changed the threshold on what is low?
Has anyone else's changed?
Dgr401
Dennis
Rhode Island
2020 Wrangler JL Sport S - Granite Crystal
That is common when there are rapid changes in temperature. My tires were in the 32-33 range and I hadn’t had a chance to air them up. We had a major cold snap and all four went down to 29 overnight. I see you are in Florida, are you in the area that had the cold snap? I doubt if Jeep changed anything.
Willys.JLU.2021
Willys.JLU.2021
Lance
Yes temps have been cold but recently warmed up but the light is coming on at 35 lbs, I just thought under 30 lbs is what made light come on but maybe it's a different calculation
flick2614
Randy
AZ
2021 Jeep JLU Rubicon Diesel
That light burnt out long ago on mine
Willys.JLU.2021
Willys.JLU.2021
Lance
Lol...aired down more often that not?
ArmyRN
Paul
Longview, WA
1946 Willys CJ2A, 1998 Jeep TJ, 2023 Willys JLU
A tazer can allow you to set a lower parameter.
Dgr401
Dennis
Rhode Island
The light won’t reset until the tire (s) have at least 36 lbs in them. Fill them up to 36/37 to see what happens. If it resets you can reduce the air pressure to your liking.
flick2614
Randy
AZ
Aired down a lot, don't replace TPMS when they stop working, just generally ignore that light always. Lick your finger and stick it to the sidewall to check the psi, works much better.
3arl0fBruce
Rob
Northern VA
'23 Wrangler JLUR MT - Earl
In my experience, if any of your tires dipped below the low threshold, and triggered the light, they will need to be aired up to the high threshold (37 psi, I believe) to get the light to go out. You can then air back down to your preferred pressure. Tazer and JSCAN both allow you to alter the thresholds at which the light goes on and off.
6.2Blazer
Ohio
2019 JL Sport
So you are saying that the display showed they had 34-35 psi and the light was on? Has it been abnormally cold in your area recently? Likely what happened that the cold temperature caused the pressure to drop low enough to trigger the light. Than the temperature went back up and the tire pressure went back up. If the light comes on at 30 psi it will stay on until the tires are inflated all the way back up to the threshold pressure (37 psi according to the above). So if they went to 30, triggered the light, and then went back up to 34-35 psi the light will stay on until you put more air in them.
alphawolff
california
2021 JLU
Once the TPMS warning is thrown it won't clear until it reaches the proper PSI. If it snaps to 29 PSI on start but quickly warms up to the mid 30s it won't go off by itself.
The threshold is customizable with the tazer or other applicable tool
Willys.JLU.2021
Willys.JLU.2021
Lance
Yes it was cold in my area the night before in the high 20s..It possibly could have caused tires to go below 30 but when I left the house tires where at 35 with low tire pressure light on and message saying inflate to 37. I am now at 36 and everything has now cleared. As someone on here said i think once it went below 30 it wouldn't clear until I hit 36 but now probably won't trigger the warning light unless I got under 30
Willys.JLU.2021
Willys.JLU.2021
Lance
Yes sir that is exactly what happened..thanks
