Loose hinges (not paint bubbling)
Riotfunk
Ma
22 Willys with 2 Doors
Anyone have the issue where you have to have the door hinges and the body side hinges replaced?
I noticed a rattle in the door about 1k miles ago and then noticed the paint in the door jamb has wear marks from the door shifting slightly while driving.
Was told bad hinges. You can grab the open door and wiggle it up and down just a bit. It’s even chipping the hinge paint. Looks like they were made out of spec somehow.
There’s no way to adjust the play so I need a dealer with a body shop to fix. Closest decent one is 2 hours away
again anyone have anything like this? Shop said first they’ve seen on the JL at their shop.
1Evil55
here
2018 Sport
First one they've seen, since the last one. How is the paint around the hinge? Bubbly?
Riotfunk
Riotfunk
Ma
The paint is fine. Minus the hinge chipping some from the hinge. I have 4500 miles. Only got few months ago
Riotfunk
Riotfunk
Ma
The paint bubbling isn’t the issue.
The hinges where the door mount to the body are loose letting the door shift a little while hitting bumps
Wabujitsu
Sarasota, FL
2021 JLUR, 2020 JLU Sahara
Retired US Army
My wife’s 2020 JLU Sahara had doors that were crooked, but not moving. The body shop at the Jeep dealership had to fix it. Bad QA. They did it quickly, with a loaner, and they are perfectly fine now.
Riotfunk
Riotfunk
Ma
This is the issues I’m getting where it is wearing off the paint and rattling. The door hinges/pin have a decent amount of play in it and rattle constantly when driving. You can grab the door when open and rock it up in down in the hinge.
Jeep Wrangler JL Loose hinges (not paint bubbling) IMG_6730
Jeep Wrangler JL Loose hinges (not paint bubbling) IMG_6729
Jeep Wrangler JL Loose hinges (not paint bubbling) IMG_6744
Jeep Wrangler JL Loose hinges (not paint bubbling) IMG_6741
Here’s a short vid of the clunk.
And this is where my rear gate doesn’t sit flush by a good amount at the top corner above the handle. I get a rattle here too. There’s no way to adjust to get it to stop or sit flush. All my doors also close fine. But yet they all rattle.
Jeep Wrangler JL Loose hinges (not paint bubbling) IMG_6737
mwilk012
2018 Ocean Blue JLU Rubicon
Service
You adjust it by removing the hinges, I don't recommend you try it.
Riotfunk
Riotfunk
Ma
I’ve adjusted as much as you can. The hinge holes for the door pins are too big causing the door to move.
