Looking to buy first jeep
natzuen
Nathan
colorado
none
I'm looking at buying a 2020 Jeep Wrangler Willy's sport, I'm curious about what things should I be looking for on the test drive, and when looking under the vehicle? Also I've heard about the death wobble, and it has my wife concerned. This will be a DD along with light to moderate off-roading and my son does ride with me a lot. Is it a huge thing to worry about?
whitechocolate
Fl
2021 JL 80th Edition
Since you're buying used see if you can find a CPO, you'll get a 6yr 100k/bumper to bumper with no bullshit warranty.
John VonJeep
Middle of Nowhere
Many
DW is most likely to arise traversing oscillating pavement where the two sides of the axle are moving asynchronously, often on certain bridges. Does the Jeep have a lift? Stock DW is fairly rare.
natzuen
natzuen
Nathan
colorado
none
No lift from I’ve seen other then stock lift for the Willy’s version, it was a prior lease vehicle.
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
... my son does ride with me a lot. Is it a huge thing to worry about?
As long as your son doesn't pull on the steering wheel while you're driving, unbuckle your seatbelt, etc. you should be fine.
Reinen
Utah
2021 Jeep Wrangler JL Rubicon
In spite of its name, Death Wobble rarely causes death or even injury. It's just really disconcerting and has been given a dramatic name. It's caused by loose components in the front suspension and steering components. So check those, there should be zero play in any of them. If any component can be moved by hand even the slightest amount it's a problem.
For CO, which is high altitude, I strongly recommend the 2.0T engine. The 3.6 is quite noticeably weaker at the altitudes you'll be wheeling.
kah.mun.rah
Merenkahre Jr.
Duat
For a 2020 I would check the hinges for corrosion under the paint and avoid one with adaptive cruise. That said, I am not sure if adaptive cruise was even an option for a Willys Sport.
Check the bottom for signs off off-roading damage (scrapes and dents). Look at the steering box and avoid buying the Jeep if the pump is silver (aluminum). Check your dipstick and coolant overflow tank to make sure that there isn't coolant in the oil or oil in the coolant. Instead of a 2020 with an aux battery, move up to a 2021 with eTorque.
Guinevere
Robert (Bobby)
San Diego, CA
2024 Wrangler Rubicon 4DR, 1999 Wrangler Sahara
lf this is your first jeep I highly recommend getting a TJ…
Heimkehr
Pennsylvania
2021 JLU 2.0T
I'm normally on the side of disregarding dramatic nicknames, like "Death Wobble", but this one is a rare exception where I don't mind its use.
One of my pre-purchase test drives was in a JLU where the so-called wobble came on fast and furious just after reaching interstate speeds...at which point the condition demanded and got my immediate attention. I'll admit that it startled me.
Having been away from Jeeps for 25 years, and not yet having joined this forum, I had no idea what was happening, only that it was occurring and that it was dangerous. My only concern was whether I could safely slow the vehicle without being rear-ended. I could, and I wasn't.
So, for those unfamiliar with and/or not expecting Death Wobble, it can indeed seem very serious when it happens. I'd say that's because it is just that.
The DW that I describe occurred on a box-stock Wrangler, no less. So, I'm not as quick to dismiss or redirect the matter as others might choose to do.
Reinen
Utah
But did you die??
...no?
I still contend it's a dramatic name. 😁
dchemphill1
Nebraska
2020 Wrangler Rubicon Recon
School Administrator
If the 2020 is your purchase first thing to do is remove the small battery and never put it back. Stupid design that can lead to all sorts of issues. Plenty of threads about it. If it is a lease highly unlikely anyone wheeled it off road.
BobW
Bob
Ventura County
2018 JLUR 6sp MT; 2019 GC; 2021 Lego JLR
Well, no sudden moves, it's not a sports car.
The only scary thing I've had was getting kicked by very high side wind gusts on CA-14 north of Mojave, had to slow down since it felt like I might get blown over...
On the plus side, a Wrangler is a full-size Lego kit.
