bugnuker
I recently bought and installed the LOD Destroyer Rear Bumper with Tire Carrier on my 2024 JLUR.
I have some things to note that will hopefully help future customers of this product, and I am in need of some help as well.
First things first - my Jeep is a 2024 Rubicon X, 35 inch tire package. When you get this package, it comes with the Mopar gate reinforcement for the bigger 35 inch tire. This is NOT COMPATIBLE with the LOD Tire Carrier. You must have a stock setup - and it's not just as simple as removing the Mopar gate reinforcement - no no. You need the standard carrier, shorter bolts, hinge bolts, etc.
So if you are considering buying this setup, be sure you do not have some other tire carrier. Or, if you do, be sure you have the stock bolts for the carrier to the gate, and the stock bolts for the hinge bracket.
Next is the backup camera relocation - this is where I am looking for some help.
I bought the relocation kit but I am not able to find a good way to wire the relocation extension wire. I have removed the panel on the tailgate, and I can see the wire, but it goes into a panel on the rear passenger side and I am unable to get that to go anywhere.
Has anyone else installed the backup camera relocation for LOD bumper? Can you share how you wired it up?
I'll continue to update this thread with pictures and other things I have learned along the way, as well as install videos that I used that helped me out.
LOD does not have an install video for this - they have one for the JK, and it's somewhat similar, but you should not rely on it. with the JK, you had to drill into the frame. Not with the JL. Simple things like this difference are important :D
