Locker Position Sensor Potting - DANA 44
chevymitchell
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
Thank you @chevymitchell. I just completed potting my sensors (2018 JLUR with 12,900 miles). There was a small amount of oil in the rear sensor, the front sensor was dry. Thanks to your instructions, everything went well and I have hopefully avoided a future failure.
You’re welcome man. I just did @UNC Rubicon ’s sensors today. Both of his had oil with the rear sensor about half full. Hopefully we can catch a bunch of these before failure. Glad it worked out for you.
Ospreyfe55
Marc
Navarre, FL
2020 Jeep JLU Rubicon
Is there any issue with re-using the diff cover bolts? From what I read the torque sheets state that you need to use new bolts on the diffs! If reusing the bolts, do you recommended any type of loctite/ Blue? Red?
chevymitchell
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
No issues. You can use some red Loctite on them.
redsyphon
North Florida
2018 JLU Rubicon
IT Project Manager
Well, both sensors are curing now... Hopefully all goes well and no issues after reinstall ?
Both sensors were dry on mine, 2018 w/19k miles.
FinnCustomKnives
Woodstock, GA
2021 Wrangler Rubicon Ecodiesel
Well I will definitely check out my sensors when we finally pick it up and report back. It really would be interesting if they have in fact solved it as they say, but are still delivering newly manufactured vehicles with said fault potential sensors.
CenTX JPR
Central TX
2018 JLUR, 05 TJR 6spd
Finally got to this, thanks again for the write up. Had oil in the rear, thoroughly cleaned it out with brake cleaner, then potted. Front was dry but potted it as well. Used red Loctite on the sensor bolt, blue on diff cover bolts. I did not remove the carrier bolt. I did a short test run with them locked, all seems ok.
I was concerned about the drill bit biting and pulling thru too deep, so I used a 3/16 rivet as a depth stop, but afterward I don't think it was necessary. Bit protrudes a little shy of 1/8". Here are my few pics.
Jeep Wrangler JL Locker Position Sensor Potting - DANA 44 IMG_20210207_170527934
Jeep Wrangler JL Locker Position Sensor Potting - DANA 44 IMG_20210207_172410977
Jeep Wrangler JL Locker Position Sensor Potting - DANA 44 IMG_20210207_170711843
Jeep Wrangler JL Locker Position Sensor Potting - DANA 44 IMG_20210207_173601682_HDR
Jeep Wrangler JL Locker Position Sensor Potting - DANA 44 IMG_20210207_172140833
Jeep Wrangler JL Locker Position Sensor Potting - DANA 44 IMG_20210207_171323752
Jeep Wrangler JL Locker Position Sensor Potting - DANA 44 IMG_20210207_171422012
Jeep Wrangler JL Locker Position Sensor Potting - DANA 44 IMG_20210207_172226692
Jeep Wrangler JL Locker Position Sensor Potting - DANA 44 IMG_20210207_172344106
TROYXTROY
New England
2020 Rubi
I like the rivet idea! Thanks for the info....
chevymitchell
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
No worries at all. I'm glad you got around to doing it before it failed.
I must caution against brake cleaner and electronic components though. Brake Cleaner will essentially ruin any solder runs on exposed PCB's. You must use contact cleaner.
Using the rivet as a drill stop is a good idea. Definitely will prevent hitting the pcb like this.
Jeep Wrangler JL Locker Position Sensor Potting - DANA 44 1613696734200
CenTX JPR
Central TX
Thanks, guess I should have known that. I did thoroughly blow them dry, and I hope it fully evaporated before any damage. My thinking is this will get me by until a sensor is available in the future (if mine fails).
RubiconToad
Moline IL
2020 Jeep Wrangler JL Rubicon - Granite Crystal
Any reason why it seems to happen more often to the rear as opposed to the front sensor?
I assume it’s due to the rear diff seeing highway speeds much more often than the front, keeping the sensor covered in gear lube for extended periods.
DanW
It is truly mind boggling that they don't have a simple replacement for these sensors. It would save them just an incredible amount of money and hassle. Plus, it is just a big waste of perfectly good axles and a lot of steel.
CarbonSteel
Smells like a class action lawsuit in the making for those who have a failed sensor out of warranty.
