SwissSteph
- Steph
- Oct 29, 2019
- Switzerland
- Website
- www.swissjeepjl.com
- JL Wrangler Rubicon - Hella Yella - 2.2 Diesel
- Vehicle Showcase
- 1
Thanks again for this topic!
Thanks to the very clear explanations of the first message AND the video, I managed to make my back.
Although for the moment it's the front that is broken (my dealer is not motivated to do something, justice will take over!), I put the cable of Z_Automotive (on the front) and this removed the witnesses on my dashboard.
This morning, when I took off the rear, I already had some oil in it, I drilled the three holes, cleaned it with fein cleaner, put the seal on and reassembled it this morning. Not yet checked if it's good or not, normally I had no more lights on my dashboard. I hope my modification didn't make the situation worse when I cleaned the oil inside.
Anyway.
I noticed that with a simple "Torx T20" screwdriver it's possible to remove the screw from the part WITHOUT touching the "Cap bolt" (which is a plus for me, I had a lot of stress having to remove these two bolts)
As mentioned above by a member, I managed to clean 100% of the "pot" injector in my kitchen with hot tap water, perhaps this information could be useful to others.
Anyway.
