Locker connector needed and unable to find
Mchris
Michael
Washington
2020 wtangler
Hello all! I am swapping 2019 Rubicon axles into my sport that I got from an engine fire jeep. The locker plug and internal connector was damaged-see pics.
I have purchased the external wire and the female to female plug already that goes into the housing.
I just need to find the correct plug so I can cut off the melted one and splice in the new.
I've tried searching the part numbers online with no luck with general searches of the numbers engraved and at Eaton website. .
Can any of you help with getting just the male connector part number for purchase without buying an entire Eaton repair kit?
Jeep Wrangler JL Locker connector needed and unable to find 20250329_140810
Jeep Wrangler JL Locker connector needed and unable to find Screenshot_20250329_150343_Gallery
Jeep Wrangler JL Locker connector needed and unable to find Screenshot_20250329_150319_Gallery
Mchris
Mchris
Michael
Washington
2020 wtangler
*This is the front axle in case that matters
roaniecowpony
Retired Engineer
I'm sorry to be the bearer of bad news, but that axle assembly is toast, IMO. I'd try to get my money back. It's all heat affected from the fire. Those brown, straw, blue, purple colors are indicative of the metal reaching specific temperatures that affect the heat treat. That actuator coil that you want the connector for, likely doesn't work after being heated that high, and you cannot buy that actuator coil.
Mchris
Mchris
Michael
Washington
2020 wtangler
Update: That connector is supposedly CE4108 and looks right. Ranges in price from $30-90 which is a bit ridiculous.
Actuator works with a 9volt battery easily.
I haven't cleaned up the inside yet and it was sitting dry for awhile before I picked it up. I'll replacing the seals to safe so will get a better look at possible heat great colors when the gear is out. Fingers crossed it cleans up nice.
Thank you all! I'll try to remember to update this thread in case someone else need to get that connector once I confirm it's correct
roaniecowpony
Retired Engineer
I'll give you a connector. Message me
