MMcClain
Need some help locating part numbers for the main harness side connector and pins for the left front wheel speed sensor.
Background: had the ABS, service 4WD, and stability light come on. Checked, shows left front wheel speed sensor invalid data to ABS module. Checked live data, left front showed 9RPM steady. Replaced the sensor kit, now it shows 0RPM, same lights. Could I have a bad sensor from the stealership, sure. But more likely, I think, a pin in the connector is done. Help locating part numbers would be great, or anything I’m missing? Thanks.
