Lift kit installed, side to side difference exaggerated
Roky
Roky
What part number do you have? This is crazy
It is beginning to sound like they have no idea what they even sell. Both my rears are same part number.
What I think is crazy , is Maximus using another companies spring........:facepalm:
JimLee
Jim
Too damn close to Death Valley
'19 JLU
I saw a video last year from a lift manufacturer and supposedly there are only 2 maybe 3 companies in the whole world that produce coil springs to order. The message was, regardless of what you think you are getting most of you are getting the same coils, rebranded.
Redbaron73
Redbaron73
Ronnie
2020 sport s unlimited;2020 Rubicon Unlimited
@Roky is correct. This is straight from the install instructions
As pictured above - I have 2 driver side spring seats. I do not have a pass side spring seat.
Also the instructions are completely different. There is NO "D" or "P" marking on either front or rear springs.
Redbaron73
Redbaron73
Ronnie
https://rockkrawler.com/jl-rear-spring-correction-seats-18-pres-wrangler/
Maybe Maximus chose not to use the RK spring correction pads. You can order them for $20 versus buying new springs. Of course call them first as it says for JL's with standard JL springs.
What I have is REAR - Part #RK06845. It included 2 pads, and those replaced the OEM pad. Neither spring is marked as "D" or "P", and both pads and springs are same size. The OEM pad was almost the same as the one included with the RK.
Roky
Roky
That would explain it.
Roky
Roky
Yeah..... this is at least 1/2” of your problem.
JimLee
Jim
'19 JLU
Take a good look at the bottom of the pads closely and under good light, if I remember correctly the D and P were pretty hard to see being black on black. Worth a second look,
Redbaron73
Redbaron73
Ronnie
So the PADS are the ones that are marked, not the springs?
Redbaron73
Redbaron73
Ronnie
@hoag4147 @JimLee @Roky
You guys got it right!! I went out and did a visual inspection. Not easy to do on the driver side based on the way the Maximus 3 bracket is installed. The pad that is on the driver side is .5" taller than the pad on the passenger side. It is plain as day *NOW* that I know to look for it.
If you take .5" away from the driver, and add it to the passenger, guess where you end up :)
@Rock Krawler Suspension & @Maximus-3 This information might help you in the future.
The bottom line - it was an ID-10-T error on my part, with focus on the springs vs the correction pads themselves.
Thank you everyone. Now I just need to find time to tear it all down again!
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
Sorry you have to tear it apart again man. Glad you found the problem. Should be happy when corrected :like:
Roky
Roky
I’m sorry... I didn’t realize that Maximus uses RK springs, I could have been more help in my post # 6 made back in November......:facepalm:
