Lift kit for overlanding
zoki
WA
22 JT Mojave
I know that there was 100 posts about lifts and i'm not asking which one is the best.
I see there is a lot of people that went trough couple different ones.
From your experience what would be good setup for JL Rubicon mostly used for overlanding (35'' tires, bumper +winch, exoskeleton rack, big rtt...)
So far i didn't need lift as there was no crazy off road but im moving soon to place with a lot and even for overland i will need lift as im constantly adding stuff.
It's also a daily driver so i would go 2.5-3 in...
Tpom
Tyler
Olympic Peninsula - WA
2021 JLUR
I have not had it installed as of yet (few more weeks hopefully!) but I bought a Clayton Overland + 2.5" kit. I will be running 37s with it. Although I do not like the word overlanding really anymore, that's my build path. It will be running a Gobi stealth rack, RTT, bumpers, winch, etc. Clayton builds in the bumper and winch weights already, then increases the stiffness of the springs to handle quite a bit more weight.
When you say "big RTT" do you mean a 3-4+ person one? I would be conscious of the weight that high up. Just some food for thought. The 35s will help in width though.
TX_Ovrlnd
CStat, TX
'22 Zilver JLURD
freethinker
If carrying weight is your plan you’d probably want to go AEV or Clayton, they design their kits specifically around heavier load outs. Call ahead if you have a weight in mind as it might necessitate a spring change prior to purchase.
Edit: I have a Clayton 2.5 Overland+ and it rides fantastic.
zoki
zoki
WA
22 JT Mojave
thanks guys...i was looking at it today...
what shocks do you run with that?
is there any other stuff that is not in the kit but needed?
TX_Ovrlnd
CStat, TX
'22 Zilver JLURD
freethinker
I’m running the JKS Fox 2.5s, the Clayton kit is designed around the Fox 2.0s. My installer recommended new spring pads for the front, I believe he used Rock Krawler ones. AEV’s kit comes with everything you need, but it uses geometry correction brackets instead of control arms.
Tpom
Tyler
2021 JLUR
Deleted member 59498
Guest
Damn those are expensive, whole new Jeep ride though? What would a good shop cost to do the change out any idea? Or do it yourself? Awesome they have the diesel springs
Joe98
Sydney
2019, 2 door Sport S, Mojito!
Overlanding means no really tough terrain, so you don't really need a lift.
Reinen
Utah
2021 Jeep Wrangler JL Rubicon
But you do need a suspension because stock springs, shocks, arms & bars won't handle overlanding weight. That suspension nearly always involves a lift as a byproduct of handling weight.
MtCamper
Ken
NW Montana and Yuma Az
2018 JlUR White Rubi, 2022 Chevy 3500, 2016 27-5L
Retired, Snowbird
I wheel with two other JLURs. One has a full Metalcloak suspension, one has the OEM 2" lift and I'm running a 2.5" Rough Country puck mount lift. We're all pretty happy with our rigs, all can go the same places and the rides are pretty similar. I carry about 250# of extra weight and the MC guy is about like me. The OEM owner is pretty minimal. If I were to get into overlanding with more weight, I'd keep my cheap puck lift and add air bags. Don't know if I'd keep that setup long term but it's a place to start and pretty easy DIY solution for only a few hundred dollars.
zoki
zoki
WA
22 JT Mojave
yes and no...depends on the terrain...
so far i did't need clearance that much but i will in the future...
zoki
zoki
WA
22 JT Mojave
$700 bucks. hahahaha no. I'd make a fun day out of it with a 12 pack and make sure it's done correctly
i would too...
i love working on the cars but currently i don't have a garage or time to do something like that...
im afraid it would end up not being a fun day (except for 12 pack) and multi day project...
