Lift kit advice
mattjryan1973
North Carolina
2018 Wrangler unlimited JL
I have a 2018 JL and after a few trips wheeling in it basically stock I want get it lifted so I get up to 35” tires on it. Been looking at the 2” MOPAR Kit. Any advice or recommendations would be helpful.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
The Mopar kit is pretty decent, it's a spring kit, gets you a solid set of Fox's, extended bump stops, extended sway bar links, and new LCAs that will help with caster.
Most kits are going to measure lift from a Rubi, so you'll probably end up with 3"+ if you have another trim.
I definitely wouldn't pay dealer rates to install it, especially since you're toward the end of the factory warranty anyways.
If you don't have a Rubi, you'll probably want sway bar quick disconnects, instead of solid links like you'll get in the Mopar.
Rubi SoHo
Brinton
2021 JLUR-XR
Physician
Do some research on whether you should regear to run 35” tires. If a Rubicon, probably not necessary. But if a non rubicon, I’d probably do it. Some people don’t though.
35’s have a LOT more rotational inertia than your standard wrangler OEM tire size, without regearing, you’re going to notice that big time in acceleration, transmission behavior, fuel mileage etc. 35’s on standard 3.45 or even the 3.73 gears available to the non-Rubicon trim levels will change the way your jeep feels in a significant way.
word302
Oregon
JLU
Rock Krawler or Metalcloak. The Mopar lift is incomplete and not great for what it costs.
mattjryan1973
North Carolina
What kind of gearing would you suggest
Rubi SoHo
Brinton
2021 JLUR-XR
Physician
If I were doing it, I’d go for at least 4.10, and try to match the standard Rubicon’s gearing. Or 4.56 like the XR.
Jeep’s put 4.56’s on their XR package even with the auto-tranny. Overkill? Maybe. Maybe it’s in order to keep those owners comfortable when they go to 37” tires, as many will? Maybe their engineers deem that the proper gearing for running the 35’s the XR package comes with on the JL? Either way, I’d personally be regearing.
Zandcwhite
Zach
Patterson, ca
2019 jlur
It’s like everyone just forgot about the jk all together. A jk rubicon came with the same 4.10 gears…and a transmission with a taller 1st gear. The jk rubicon on 31’s and 4.10’s has the same effective 1st drive ratio as a JL on 35’s and 3.45 gears with our 4.7-1 1st gear in the 8 speed. Obviously the lower gearing is one of the things that makes the JL so much better than the JK. Lower gearing would be better, but clearly isn’t necessary as it will literally drive like a stock JK rubicon. Personally I wouldn’t spend the money to regear sport/Sahara axles. Spend a couple hundred dollars extra and buy a set of rubicon axles. You get 4.10’s which are great for 35’s, wider axles for better clearance with the 35’s, and lockers.
Greg H
Greg
Vallecito Lake, CO
2018 Wrangler Unlimited JL Rubicon
This video review of 6 different lifts may help. After watching this video and reading a lot of online reviews I went with the Dynatrac Endurosport 2" lift. Glad I did. Maintained the factory ride and handling on road. Absorbs large bumps better off-road. I'm running 315/75/17 (35") tires on my stock Rubicon wheels. No spacers required other than on my stock spare tire mount. Added a 7/16" spacer to keep it from smashing the rubber bumpers on the rear door and touching the rear wiper blade. The Ultimate Jeep Wrangler Lift Kit Comparison – On & Off-Road Test - YouTube
Stuckinthesand
CJ
NJ
2019 Wrangler Sport S
Depending what kind of off roading you plan on you could look into a spacer lift. I run a 2.5” RC budget boost with 35”s on my 19 sport. I’m still running stock gearing but I do have the M220 rear. Only thing I did was bought shocks for a 2.5” lift instead of running shock extensions. I run blue rated trails at Raush creek and AOAA in Pennsylvania and have done 3 BOH trails(trail 11, crawlers ridge and crawl daddy) with no issues on my setup. I don’t plan on running anything bigger than 35”s and the trails I run are about the max I’d
go.
Jeep Wrangler JL Lift kit advice 1BF3D0C3-0FD7-4F90-8AA4-BCA0E69D4F30
Jeep Wrangler JL Lift kit advice F7507248-A2C4-49A6-A8B1-693A2B8485F6
Jeep Wrangler JL Lift kit advice B3ADFDAD-6196-4248-8E9B-2BD7C0B72D22
Jeep Wrangler JL Lift kit advice E257977F-AE1B-4C94-86F4-26109A77E04F
lowmpg
Ryan
Kent Island, Maryland
2021 Rubicon, 2025 Ram Limited
Enjoyed this review when picking mine...
