Lift kit advice, Rock Krawler a solid choice?
JimLee
Jim
Too damn close to Death Valley
'19 JLU
For sure, did you even bother to read? Just letting people know about your ongoing powder coating issues. That’s what these forums are here for. I wish I had known about it prior to getting a kit.
So let me see if I have this straight. You had an issue, RK fixed it, and now you are here posting old pictures and bashing them...what a douche.
JimLee
Jim
'19 JLU
I do not believe any after market company put more R&D from engineers with degrees into a lift kit than Mopar. It is not for extreme articulation but works well on tails like the Rubicon Trail and other Sierra/Rocky mountain rock crawling tails I've done with 37" tires. No issues in over a year and 13,000 non DD'r miles.
You know what I do for a living? I keep engineers (with degrees) from damaging/destroying my customers military aircraft, and they sure do keep me busy. Lol. I think it's great that your Mopar stuff works good for you, but for some of us it's just not enough. I also know that factory engineers are constrained by weight, cost, fuel efficiency, safety standards, legal departments, etc. I'm sure if Jeep engineers were cut loose of constraints they would design a truly bad ass offroad beast. But then again it would probably cost well over 100K and get 3MPG.
Artvandelay
NY
JLUR
Lol here come the RK friends, family and shills. Douche, no a douche is doing what youre doing. Saying I’m bashing when im just here stating the facts. It’s shady af for them to be saying that they’ve fixed things when they obv haven’t. It’s simple. Integrity. I said all I needed to say. It says a whole lot about a company if that instead of telling the truth they’d rather have people that have nothing to do w the situation cause drama. So, this goes to anyone that thinks any certain way about what I’ve brought up. Read again. The Jeep was hardly driven and everything oem around the parts the coating is stellar. Fyi, lol rust is a whole different animal than your Powdercoat coming off in sheets smh. But hey. The truth needs no explanation. The pple that matter will see this as what it is.
Artvandelay
NY
JLUR
Well if I get a lift kit, Ill be getting rock krawler. Look how much they posted here and stand by their product!
lmao. Best shill everrrrr. In a thread where they were caught red handed lying.
Jimbo1226
Jim
In a Jeep
2015 JK, 2018 JLUR
I don’t swing from any company’s nuts but from the sounds of it, RK took care of what they needed to and after you got what you needed, you went to a forum to bash.
sounds like you’re just out here trying to start something rather than being happy that a company actually followed their warranty and took care of you.
JimLee
Jim
'19 JLU
Haha,I hope you realize those are just your opinions. Who desgined the aircraft. Folks with engineering degrees. Same folks that designed our JL's, not aftermarket folks.
Sorry Ben, I can't get on the engineer worship wagon. There are good engineers and there are bad engineers, having an engineering degree doesn't make them superman. Counterpoint to your point: Everything that has ever broken was engineered.
JimLee
Jim
'19 JLU
Lol, this Karen actually thinks RK called us on a batphone to come here and defend them. I think he's got some issues.
Jeep Wrangler JL Lift kit advice, Rock Krawler a solid choice? 92844898_2489111904644665_918912530766626816_n-8
Ruby Mike
Michael
Southern California
2020 jeep wrangler diesel
I happen to be involved with powder coating (PC). Powder coating is an involved process. What we do is first remove all existing paint/powder through the use of a gas fired burn off oven. The product is then abrasive blasted to remove any residual material and to provide the proper surface condition (anchor tooth) for the powder. Next we prep the work, apply sealant and ensure proper surface condition. We have a very short time allowed from blast to coating, because if bare/blasted steel is allowed to sit longer than 3 hours, the humidity will cause surface rust, rust flash. If powder is applied over surface rust, even if not detectable by visual inspection, the coating can fail. Any product that sits longer than 3 hours is reblasted and cleaned. We use a process called "frocking" because of the shapes and configuration of the process line. The best way to coat is through electrostatic coating. So we pre-heat the product to drive off moisture and prepare the surface to accept the powder. Product is primed, using zinc rich primer then the top coat is applied. From there the product goes through the curing oven. All product is inspected for defects and what is known as correct dry film thickness. Typically about 8 to 10 mils. Any product failing QA has the process repeated. Typical defects include orange peeling, out gassing, excessive or deficient dft, blistering and so on. The critical part of the process is the product material must be clean, dry and free of any rust flash and have the correct anchor tooth.
RedundanT
So. Il
2020 JLUR
Wiener wagging, and nothing more. RK is OK, not great and not bad. There are several lift companies with just as much experience, cred and quality. Get over it.
Goosed
Ohio
2020 JLUR
I had a RK lift for some time on my JK, live in NE OH and they bribe and salt like crazy. I did not have issues with peeling powder coating at all. I probably should have. If the winters get mild they blast a ton of salt to get rid of it.
If there are issues people are having, they have to be isolated and not mainstream issues.
