Level 2 Charger Install
AJ_4xE
AJ
Atlanta
Toyota
I paid $350 for a local electrician for installing the 14 50 nema plug and he brought all materials except the wire....and I installed the charger which is easy if you have a stud finder
GoldenKnight
GoldenKnight
IL
'21 HA 4xe
Yeeesh. This was the actual proce. Called several local places as well and everyone was at $1,700 or more.
Location, plus "new normal", plus them knowing I can offset some through taxes may explain the ridiculous cost.
It was just completed yesterday, I had scheduled it on August 8th and September 15th was their first available date. So apparently there's no lack of work for them.
Snazzy4xe
New Jersey
‘21 Sahara 4xe
As a Sparky myself,I will tell you that electricians can be pigs when it comes to charging for ANY electrical work…but we will definitely charge more if it means working In a crawl space or squeezing into attic space…just being honest…most people are terrified of electricity(rightfully so if you don’t know what you are doing) and Some guys will take advantage
GoldenKnight
GoldenKnight
IL
'21 HA 4xe
Unfinished basement straight up into the garage, so nothing weird there. I knew it wouldn't be cheap, but it was probably $500-600 more than what I thought was reasonable.
I can do some basic electrical work, but no way would I run a new 240v line. Conduit is required for all electrical in Illinois so I wouldn't want to mess with that too.
Terminex
Omaha
2021 JLUR 4XE
Fixing stupid....
I just had mine done a week ago.
installed:
100A sub panel in Garage
2x 50A 14-50 240V outlets
1x 20A 110v outlet
Finished basement where the service panel for the house is located.
approx 100ft run from basement to garage (and it was b!tch for them to run it over some of the air ducting) they also replaced the cut drywall but did not mud or paint.
conduit installed from sub panel to all outlets in garage, each outlet was about 35 ft run.
install was $2800.
Black96z
Houston
2021 Rubicon 4XE, Tesla Model S
Machinist, Applications Engineer
The wire is $4-$5/foot right now, plus they will mark it up from there. The breakers are $10 for non GFCI, $100 for GFCI. You can do the math on the materials.
Electricity is not that complicated to do, but you have to have some basic knowledge. If the electrician shows up and sees you only have a small toolbox and no real tools, you'll get shafted because they know you probably call in someone to change a light bulb. If they see you're competent, they will be competitive.
Also, 6/2 & 6/3 are heavy not as flexible wires. It is a lot harder to pull through walls and crawl spaces, so the times to make those runs are longer. Also, if you are doing a long run to a garage, have a sub panel installed. Even if you don't use it now, if you ever want to add plugs or other things to the garage, they wont have to make the long run from the main.
sconrad24
PA
2016 Willys JKU, 2021 4XE
Got mine installed a month ago. QMERIT quoted $1500. I got a local quote from a Tesla certified installer for $520. I had the Grizzly E in the box near the spot and they installed that free of charge. He did mount the holster to close to wrap the excess line around. But oh well, I had planned on installing myself the following weekend.
