Aimiler level 2 charger
Hulluvatime
Jim
22 Rubicon 4xe
I purchased this charger on Amazon about a month ago along with a dryer plug adapter.
https://www.amazon.com/dp/B0BWRXBDY3?psc=1&ref=ppx_yo2ov_dt_b_product_details
Charging is reasonably fast, about 4 hours to full charge when set at 16 amps. Several times the dash charge lights stayed on after charging for many hours. This previously didn't caused a problem and the battery was fully charged. Then yesterday, after this happened, I could not put the Jeep in gear and there was a red charging light on (the one on the dash that looks like a plug). I turned the Jeep off and on, shifted 4wd in and out, turned the wheel, etc. No luck. I drove my truck instead. So today I decided to plug in the OEM level 1 charger to see if that would do any good. Voila. No issue anymore. Anyone else run across a similar problem? I'm wondering if this charger, which got great reviews, is the culprit or if Jeep simply didn't do a good job with the charging system management.
Dabrakeman
MI, USA
Wrangler Sahara 4xe
Can only suggest that you try to repeat your experiment and document it. If successful in repeating it try with a public level 2 charger. IF good with the public charger share all this information with Aimiler and give them a chance to ship you a new one to try.
