Leaking Beadlocks
MMalone
MMalone
Lake Mary, FL
2023 Sahara 4XE White
Industrial Engineer
First step: make sure your wife isn’t home.
Last step: clean up any forensic evidence
Sounds like a plan for this weekend. Thank you.
yokramer
A Land of Petty Tyrants
Snark Incarnate
Deleted User 38384
@MMalone
Just do yourself a favor and return those beadlocks and get yourself a set of interlocks from Icon.
They sit like normal tires, they're street legal in every state, and you won't ever have to worry about busting the ring up on the trail!
Jeep Wrangler JL Leaking Beadlocks 1000002124
yokramer
Snark Incarnate
$119????? I'll take my chances with the wife, while she's shopping at Costco.
Can probably find something cheaper at the tractor supply or something
Deleted User 38384
You know thinking about it, part of the problem might be as well that the tire keeps getting tested on the wheel off of the jeep, and maybe it's the pressure from the weight of the vehicle that's causing the weak point to leak. You might do good spray some soapy water on the actual rim, both inside and outside of the rim. For all you know it could be the inside portion of the rim that's leaking. 🤷‍♂️
MMalone
MMalone
Lake Mary, FL
Industrial Engineer
I thought of that, thus had it moved to spare... (No vehicle weight) filled it up and still will not hold air. Going to try bath tube fixture while wife is out of town.
Pictures or it didn't happen. With a rubber ducky.
yokramer
Snark Incarnate
Why wait, you cant be scared of her your whole life.
yokramer
Snark Incarnate
