Leakdown Tester, Harbor Freight
roaniecowpony
Retired Engineer
I bought this leakdown tester from Harbor Fright. Wasn't too sure about the quality at first. But I disassembled it and verified it has the industry standard .040" orifice (also the FAA required size for testing airplanes). It was easy to use and the gauges seem to be decent quality. This same device is sold under the OTC Tools brand for about 60% more. I'd recommend this tool. It's much more informative than a simple compression test gauge. Fits 10mm, 12mm, 14mm, and 18mm spark plug threads.
If you're not familiar with this type of tester, it's been used in the aircraft industry since before WW2 and the racing industry for decades as well. It has more recently caught on with everyday professional street car mechanics and this type of device is specified in the Tech Authority Service Manual for "cylinder leakage test" of the Jeep JL.
Jeep Wrangler JL Leakdown Tester, Harbor Freight 20240224_095518
Jeep Wrangler JL Leakdown Tester, Harbor Freight 20240224_083944
roaniecowpony
roaniecowpony
Retired Engineer
I used this to confirm my engine doesn't have a blown head gasket or cracked head. It requires more work than a common compression tester, but will give you more information. It requires that you identify the TDC for each cylinder and test with it at that position. This requires that you use a piston stop and mark the crank pulley, etc..
azwjowner
Phoenix
This is one of those tools that I'd like to become familiar with using but then I realize I really hope I never have to think about using one.
ELJL
Ed
Fairfax, VA
22 Wrangler Unlimited Rubicon
Ill attest to some harbor freight items. Most quality issues are readily obvious (poor finish, poor machining, rough extrusion/casting, etc etc)
Nevertheless, their 9mil nitrile gloves are excellent! ?
