KO2 size question
k9chita
Mayo, Maryland
2018 JLU Sahara
I have ordered a JLU Sahara and purchased a set of Rubicon rims from another member of this Forum. My question is this, I am going tube purchasing BFG KO2 tires. The Rubicon comes stock 285/70R17, which are 32.8 inches in diameter according to the BFG website. I know those will fit the stock Sahara. The 285/75R17 are 33.9 inches in diameter and ever so slightly narrower. This is going to be my wife's vehicle, and will see very little, if any off roading. Is the 1 inch going to rub under normal road use? Thanks for any advice anyone can provide.
OnlyOne
Northwestern New Mexico
2021 Sport S Diesel on 37s
N
Most likely not. But there is only one way to find out.
nota4re
Southern California
2018 4-door Rubi
They will be absolutely fine. As FYI, metric tire designations are pretty easy to decipher - assuming you care. Example: 285/75-17
285 is the tread width in mm.
75 is the height of the sidewall expressed as a percentage of treadwidth. 75% of 285mm is 213.75mm
17 is the diameter of the wheel - and the oddball because it is in inches (because that's the way wheel sizes are designated).
Then, computing the diameter is pretty trivial. Diameter = two sidewall heights (converted to inches) + wheel diameter, or;
(2*213.75)/25.4 + 17 = 33.83
ThirtyOne
Chapel Hill, NC
www.jeepdoodles.com
In case you didn't see this thread:
285/75r17 on Sahara
k9chita
k9chita
Mayo, Maryland
2018 JLU Sahara
285/75r17 on Sahara
Thanks! I saw this thread, but my lack of knowledge on the offset of the stock JLUR rims led me to pose the question again. I've had a couple of wranglers before, but never made any modifications. Offset, backpacking....all new to me.
ThirtyOne
Chapel Hill, NC
www.jeepdoodles.com
Yeah. I knew it wasn't a perfect fit but I didn't go through every post. I thought some of it might be relevant.
k9chita
k9chita
Mayo, Maryland
2018 JLU Sahara
I appreciate it. I didn't like seeing the one photo of the rear fender rub. I'm looking into lifts and/or leveling kits that'll hopefully be a fix. All of this is new to me...again, appreciate the help!
LHB
south shore, MA
'18 JLU, Rivian R1S, '99 Cherokee XJ
If you can, get a pic! I'm still looking for a picture of a Sahara JL with the Rubicon stock wheels/KO2 tires. I'm very close to doing the same with my Sahara
k9chita
k9chita
Mayo, Maryland
2018 JLU Sahara
I’ll have the tires on the rims before the Jeep gets out of “D” into production. I’ll have pics as soon as I take delivery.
LHB
south shore, MA
Made my own pics and posted to another thread but applicable here as well. I think I'm going this route:
Sahara w: Rubicon Wheels:Tires.png
Sahara Rear with Rubicon wheels:tires.png
