Jumperless Aux Battery Bypass
ScotM
Scot
Southern California
2022 Jeep Willy's JL 2 Door
I just installed the 13 inch 2 AWG battery cable jumper for N3 to N1 after removing all the aux cables, relay and battery. No issues, no lights, everything works as it is supposed to. Thanks to all who have helped me over the last weeks, as I waited patiently for the correct length cable with 90 degree rings.
Magnus Taterhawk
Nath
Alabama
2019 Jeep Wrangler Unlimited
Not trying to hijack but if I removed the Aux battery and pulled 42 fuse and now main battery (brand new AGM H7) is being drained could my alternator be going out?
Magnus Taterhawk
Nath
Alabama
Possibly.
Possibly.
How did you remove the aux battery?
I removed the battery by removing front fender liner and dropping the box down. as i turned the battery to remove the Pos and Neg leads I touched the frame rail and "POW" big pop and blue light arch! (Scared the piss out of me).
ScotM
Scot
Southern California
That was most likely your high capacity fuse array getting fried when you did that. You need to check those fuses. It’s in the fuse box at the end with the five or six cables attached to it. Disconnect your main battery, then remove all the cables. Slide a zip tie under the fuse array to lift it out, check with an ohm meter.
Jeep Wrangler JL Jumperless Aux Battery Bypass IMG_4942
WashingtonWetWheeler
Andrew
Marysville, WA
21' 6spd JLUR. UD60s & 40s
Hey guys,
I did the removal of the negative cable from the main that is coming from the aux (heat shrinked around it and tied away), and pulled F42 fuse in my 2021. I replaced the main factory battery with a new X2 AGM and I have "aux switches" unavailable pretty regularly. Any idea on the cause? ESS is eliminated also via Taser.
Thank you
ScotM
Scot
Southern California
Hey guys,
Thank you
I would load test the new battery first. There are other reasons that that particular error would show, maybe an alternator issue, or do you have a bunch of accessories that are by passing the IBS, as they can draw power that the battery management system is not aware of. But i digress,, simplest stuff fi, confirm new battery is good, reset the IBS, by disconnecting the battery for a couple of hours. Then try again to see if the error occurs
Andrew
Marysville, WA
Alternator is putting voltage at 14.0v+ when engine is running so that makes me think I have no issue there. I'm wondering about the battery too, might have to take it in to batteries+ and have it tested. No accessories other than my winch which should pull no load unless I'm using it.
ScotM
Scot
Southern California
Then maybe just try and reset the IBS.
ScotM
Scot
Southern California
You are saying this is done by just pulling negative off the battery for a few hours?
Yes, it is the small rectangular piece of plastic connected to the negative terminal. Just disconnect the negative terminal and unplug the wire going to the IBS sensor for two hours, then plug the wire in, and reconnect the negative terminal
ScotM
Scot
Southern California
This document might provide a bit of additional intel.
I know the TSB says not to remove the wire connection, but I found that doing that reset the ISB. If you buy a new one, it has just been in a box, so I figured that’s the best way, and it worked for me
