JLU shaking at highway speeds
22WhiteWalker
Ricky
Detroit, MI
2022 Jeep Wrangler Unlimited High Altitude
Hey gang, I shifted my 22 High Altitude w/ 6300mi into 4H recently after the snowstorm we had in the Midwest. Since shifting back to 2H, it shakes quite violently at highway speeds (60-80mph). I’ve tried going back into 4H and immediately back to 2H and giving it a second before moving and nothing’s changed. Any advice?
19 JLUR Bright Whit3
Baba Yaga
NJ
www.youtube.com
2019 Stretched 2 door Rubi (LOL), 2004 TJR
Retired LEO
Just a guess, Maybe youre not fully disengaged out of 4H and your front driveshaft is still spinning. You really shouldnt be going over 50 in 4H.
Heimkehr
Pennsylvania
2021 JLU 2.0T
At what speed were you traveling when you originally shifted into 4H? The maximum is 45 mph
wolfdog
George
Southern Massachusetts
2006 Yamaha FJR1300, 2021 JTO, 2018 JLU Sahara
Maritime Artisan, Mayflower II
Did you go thru deep snow or slush, got ice or snow still stuck in your wheels, that'll do it!!
I've had Jeeps for years, speeds over 60 in 4 HI never a problem...maybe dangerous or dumb but never a mechanical problem!
Go Jeep!!!
Cyclrder
NYC
2020 JKU Rubicon, S213E63S, 997.2TTMT
I'm betting snow in the wheels! the 4wd system is pretty stout and simple.
  • Like
Reactions: PBJ
Dagwood
Alabama
2019 Jeep JL, 1999 Jeep xj, 2008 Scion XB, 2015 Scion XB, 1966 Ford F100, 1969 Oldsmobile
Go Jeep!!!
Yep, never done it with snow, but mud will certainly cause this.
NMPirate
Jim
2017 JKU Rubicon Recon
King Shit of Turd Island
Check and see if you have any kind of ice build-up on the front driveshaft. I had that happen a few times on my old 1976 F250. You get a bad vibration if anything is off balance at all.
  • Like
Reactions: PBJ
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
I've used 4 hi at 60-65 with no issues. I always shift in and out on the fly though and never above 50. You only need to stop to put it in 4 low.
  • Like
Reactions: PBJ
Shibadog
Bowling Green, Ky
2020 Wrangler Sport S hardtop
As stated likely ice. IF the issue continues, check to insure you’ve not thrown a wheel weight. If that doesn’t resolve it, ck the tires, you may have thrown a belt in a tire (it WILL shake very hard if this occurs.)
dcmdon
Boston and Northern NH
2022 Gladiator Mojave
Go Jeep!!!
I'm with you.
My Jeep has SelecTrac (4wd Auto) and I run it at highway speeds all the time. The axle is the same (other than the CVJs). It should not shake.
Snow/Ice/Mud inside a wheel will make things miserable at highway speeds.
