ChattVol
What extended length are your front shocks and were you forklift/ramp flexing? I imagine your setup may not allow enough droop to shift the axle alot. This is where mine got into some heavy rubbing on passenger front.I did full flex this morning, up against the bump stops. I didn't rub anywhere. Maybe luck of the draw? Who knows?
37's and 2.5" spacer lift. Maybe some that are using spring lifts aren't getting the lift they are assuming??
