Jl coolant tank question
graveyard
robby
pikeville ky
2020 jeep wrangler JL
Guys I'm going to replace my black coolant tank because i keep adding a little coolant to it so i going to replace it, was wondering what aluminum one i can get that will fit the quick coupling under the tank? I didnt want to modify the hose unless i have no choice? Thanks guys which one did you guys go with any info will help please.
LazyJL
Larry
2020 Rubicon, 2001 built XJ
Retired fabricator and mechanic
Does the overflow tank leak? If not, replacing it will not fix the loss of coolant issue.
Heimkehr
Pennsylvania
2021 JLU 2.0T
@graveyard
As it concerns the 2.0T's cooling system, there is a TSB, 0700122 REV. B, regarding water pump inlet tube fastener torque. Make sure they're properly snug, as noted in the TSB document, before proceeding to purchase a new coolant reservoir tank that may not in fact require replacement.
graveyard
robby
pikeville ky
I will
@graveyard
[/i will do that
ScotM
Scot
Southern California
2022 Jeep Willy's JL 2 Door
You can remove the two bolts behind the tank and pull it up to look under it for any pink residue. If it’s leaking that much you will see it. I’m assuming you have crawled under the jeep to look for residual coolant ? How much are you replacing (oz), and how often?
Windshieldfarmer
Randy
Wichita, Ks
2015 JKU, 2020 JlU on order
If you have a leak of any kind you will likely smell coolant. Keep an eye on your dipstick for signs of head gasket leakage (coolant in oil). Also watch your exhaust to see if it’s unusually white on startup.
Regarding the coolant reservoirs, they are known to leak and keeping spare handy is probably a good idea, even if you don’t need to replace immediately.
Angel K
Canary Island
W Sahara 2.0 UNL
There's a leak in the water pump where water often leaks, but it's minimal. I plugged it with Nural.
Jeep Wrangler JL Jl coolant tank question IMG_0183
Jeep Wrangler JL Jl coolant tank question IMG_0191
sherpaJL
Keystone State
2019 JLUR Mojito! ~ 2022 JLUR Hydro Blue
did you plug the weep hole? that’s there by design. If it’s leaking coolant that’s an indicator that the internal water pump seal is wearing out.
Stuckinthesand
CJ
NJ
2019 Wrangler Sport S
This is dead on. Not a very good idea to seal that unless you want more major issues.
AdamG
Adam
SE Michigan
2019 JLSportS - SOLD; 2026 Moab 392
Do not plug the weep hole, that can lead to bearing failure and catastrophic failure of the pump. Weep holes work with the vent hole, or may be the only vent hole, depending on the pump design. If it’s dripping on your driveway, replace the pump. If not, the. Probably not a big deal yet but should be monitored.
Source: I work for a company that makes water pump seals
