Jeep wrangler JL battery replace help !!!!
R3TRO
Pasadena, CA
'20 Jeep Willys
Film Industry
As other said... use until it dies and replace with H7. Also bypass the aux at that time unless you have eTorque.
BigRedRidinHood
Orson
Long Island
2021 Rubicon Unlimited
This is an unlikely concern, unless you leave your wrenches or rolls of aluminum foil there.
I should have mentioned I live by the ocean and take my jeep on the beach every day so we get a lot of sand and dirt in our engines and moisture from the sea. Our battery terminals corrode faster than other places, unless you live in a state that uses a lot of salt on their roads. It takes about ten seconds to keep your battery clean. I have 100000 miles on one of my vehicles and you could eat off the engine compartment. Never had a battery problem since I turned crazy haha.
garykk
Gary
Southern NM
2022 JLURD
I am still running stock batteries in my 2018 jl. 7 years and going strong. I do use a noco battery smart tender every time I pull into my garage
So you charge your battery every time you park in your garage? Maybe I’m in the minority here but you should not have to charge the battery every time you use your Jeep..
Wbino
NJ
😂😂 a couple of years on a Jeep battery…
2021 model here still going strong...probably going to replace it before the year is out just to be on the safe side.
In the north east with our normal winters.
Hd088
Hd088
Hassan
Brooklyn ny
Jeep wrangler JLU 2021
I switched to this Walmart battery a couple of years ago. Four-year warranty, 850 CCA, stores (support) everywhere.
Thanks for the info was looking this battery wasn't sure as u telling me price wise is good would great should 850 cca better I guess optima battery agm I had didnt last me 4 months
Hd088
Hd088
Hassan
Brooklyn ny
2 JLs and a JT, 150k miles between the 3...1 battery replacement. All 3 had winches that got used hard. Not sure what you guys are doing to your batteries, but it's like the visor failures in my opinion. Mostly user error...
If i switch maine battery do I have change my 2nd battery let's say main battery i put 850 cca and its good for lighting n winch which one u recommend?
andy29847
Andy
Trenton, SC
2020 JLUR
If you are going to stick with 2 batteries, both batteries should be changed at the same time. This is not a jeep thing; it is due to the science of connecting 2 batteries in parallel. As far as connecting the 2 batteries in a Jeep. both batteries should be AGM and both batteries should be the same place in their life cycle (new). The CCA (cold cranking amps) measurement is one where you just want to have enough (or as much as you can).
Heimkehr
Pennsylvania
2021 JLU 2.0T
...the Jeep is the first vehicle I've ever owned in over 40 years that I didn't get at least 5 years out of a battery.
Same! My OEM H6 AGM battery failed at four years, almost to the day. It cranked the engine just fine the evening prior, and was dead as a doornail the next morning. I replaced it with an Interstate H7 AGM that same day, isolating the ESS battery at the same time. The new battery spins the starter with reassuring speed.
The Jeep's original battery was the first 12V battery that I've used, in any application, that didn't provide at least a 5 year service life (my personal standard for such batteries.) Ah, well. These things happen.
Hd088
Hd088
Hassan
Brooklyn ny
If im putting everstart 850 agm which one should n my 2nd second please let me know which exactly i need thank u
Zandcwhite
Zach
Patterson, ca
2019 jlur
The science of connecting 2 batteries in parallel says they should be the same size as well... and we wonder why we dont get the same life out of the main battery as we may be used to? Fortunately 2 out of 3 of our Jeeps have been etorque so the aux killing the main hasn't been an issue. When the main in my JT goes I'll delete the aux to eliminate the poor OEM design.
Zandcwhite
Zach
Patterson, ca
2019 jlur
I'd delete the aux when changing out the main. Plenty of threads on here about how to do it.
Hd088
Hd088
Hassan
Brooklyn ny
So u don't really need 2nd battery on jeep ? Aux one? I can live with main battery if I swtich?
Hd088
Hd088
Hassan
Brooklyn ny
Yes, many people delete/bypass the aux.
Thanks its easy as just discount n remove ? Its more to it thanks for the info dude whn I used to have v6 engine doesn't have 2nd battery but this 2nd one 2.0 engine is believe gotta have its sport model though
