Jeep wave at Gladiators?
Should we wave at the Gladiator yahoos?
  • Yay
  • Nay
Results are only viewable after voting.
Sean L
Sean
North Carolina
??? Who's suggesting they go to an even worse engine?
According to one of their engineers, they can't shed enough heat to put more horsepower under the hood. Sounds like that's the reason the JT will not get the diesel.
Well you keep complaining about the 3.6's torque. FCA doesn't make any other V6 that has more torque, except for the 3.0 that goes in the Quadrifoglio. That one isn't built for towing under load just like the 2.0.
The heat issue you're talking about with the Diesel is actually about the 2.0 turbo. The Diesel is still planned for the JT.
mrhumble1
Jason
Denver, CO
JL Rubicon, 2-Door, Manual
I would think Engineers that have a clue could have fixed the problem if they wanted to. I think, instead, FCA is lazy and only wants to use existing parts and designs even knowing those parts and designs were for different applications. They could have made the Gladiator it's own thing, instead they stole as much as they could from the Wrangler to use. That's not terrible, but for things like the engine (and the damn rear doors) they should have tried harder.
8flat
Gary
Montana
2019 JLUR
OK maybe I'm not communicating correctly. If I were in charge of the wrangler/JT program I'd say OK, pentastar is a good engine, but too high strung for a BOF 4WD with a towing package that's designed as an off-road king. What can we do to provide more torque down low in the RPM range? Cam profile, different crank (longer stroke), different design for intake runners/exhaust ports, etc etc. We don't care that it revs to 6,500rpm, that's easy to sacrifice and move it down to 5k for the benefit of more torque/power where it's needed: 900-3,000 RPM. Hell even a supercharger package, it's expensive but GM made it workable on a ton of the 3800s with the little Eaton M-90 and their successors, those things make STUPID torque right off-idle. That same engine package in our JLs would be unreal.
Basically, FCA took the lazy/cheap way out. They have the technology to fix this problem.
8flat
Gary
Montana
2019 JLUR
LOL I just posted damn near the same thing before I read your reply next. But yeah, they could've done much better with engine design, as many wranglers as they sell I think it would have been worth a different engine setup, even if based on the pentastar.
Sean L
Sean
North Carolina
So the old 3800s were push-rod motors If I recall correctly. They are good for low end torque all right. So if they engineered a 3.6 with a Single overhead cam and 2 valve layout they might be able to pull it off. I would say that would cost the engine quite a bit in efficiency though. Not something they'll want to put out with substandard fuel economy numbers. There's a balance that has to be achieved and I certainly believe they've done a decent job of that with the Gladiator. All the more so when the diesel starts hitting the production line.
8flat
Gary
Montana
2019 JLUR
So, you are saying they can't fit a supercharger to the Pentastar in it's current head/cam configuration? I'm not sure why. Edelbrock and Ripp are offering them already. Not necessarily ideal since the compression is so high, but if the package was designed for it from the start it would have low compression to accommodate the boost, of course.
jdegrave
Tampa, FL
Kia Forte, Pathfinder, JLU Rubicon
Director Financial Systems Support & Governance
Definitely wave :jk::like:
rallydefault
PA
'18 JLU Sport S
No, it's not a Jeep. Not being stuck up or anything, really - just simple question: Is it a jeep (around here Wranglers are just called jeeps)? If the answer is no, then no wave.
Rdmitch
Ross
Elyria, Ohio
2020 JLUR, ford transit 250, 2017 Wrangler Smoky Mountain Edition
Mechanical designer /contractor and musician
Typically I only wave to wranglers, but would wave to a glad, if I ever see one on the road.
BlackRook
Ross
North Jersey
2019 Mojito! JLUR
SCIENCE!
To me, there's a check list:
-body on frame?
-seven slot grill?
-more ground clearance than a Volvo "Cross Country?"
If you hit all three, you get a wave. Gladiator definitely hits all three.
... And yes, I do wave at XJ's. Only people who still drive em are committed to their rigs. That's earned a damn wave in my book. :captain::flag::jk:
Sean L
Sean
North Carolina
I guess you could design a supercharger and as you said there are aftermarket kits available. I'm not sure how the 3.6 would handle towing a load while under forced induction as far as heat management. I still think most of your concerns are answered by the diesel engine though.
