Jeep Order Tracker - Open to Join
NDRugby
NDRugby
Northfiled
2023 Unlimited Rubicon
I changed Today to Last 3 Days and Last 7 Days. Too volatile at 1 day of data
azvbjeep03
Samantha
Phoenix
Rubicon 4xe
Thanks so much for creating this API, it's fantastic! (fellow programmer ?)
Do you happen to know how these numbers are calculated for the status data?
Is this showing that there are only 186 Purple Reign orders in total?
Also, I noticed a new line that shows 'D AZ' - does that show how many Jeeps are ordered for the state of Arizona?
Lastly, are these numbers reflective of the number of people that have entered their Jeep order to be tracked?
Sorry for all the questions, just curious to what the stats mean? :)
Jeep Wrangler JL Jeep Order Tracker - Open to Join 1664408948994
23xr392
Brandon
Ks
2023 392 XR
IDK, Mark, not much volatility for my build.?. And this is the 3 day view?
Jeep Wrangler JL Jeep Order Tracker - Open to Join ACAECEEE-700B-4D5C-BDE2-84F657D1FDC6
NDRugby
NDRugby
Northfiled
No problem on the questions.
Yes. I created the report so I know exactly how they're calculated.
186 Reigns on jeeptracker.com. The most of any color by almost double the nearest color (Hydro Blue and White keep swapping 2nd and 3rd place)
Yes. Just added it.
Yes. I can only track the data of anyone that inputs their info at JeepTracker.com.
NDRugby
NDRugby
Northfiled
? Yeah I feel yeah. 68 days at C/D and Counting. Come on D1!
It's just that the data would go to 0 at midnight every day and then grow over the day. It felt weird staring at all 0s for a while before anything changed.
23xr392
Brandon
Ks
2023 392 XR
Hope you get some movement soon. Thanks for all the time and effort you’ve put into your tracker.
NDRugby
NDRugby
Northfiled
Just an update. Yesterday, some of you may have gotten update emails that look like they had no update. Turns out, Jeep put 4 D00R (those are zeroes) for some of the Jeeps. Yesterday they fixed a bunch of those to be 4 DOOR with (o's). That triggered the app to see a change. Hope that clears up any confusion.
Nitehawk92
Vandalia, Ohio
23 JLU Reign Rubicon 14 Mazda, 22 Hyundia Santa Fe
Retired Air Force Current Civil Service Civilian.
Glad you like it! Thoughts on the color coded background that matches your Jeep? I went back and forth on doing that one.
Awesome to have the background color of the Jeep...
NDRugby
NDRugby
Northfiled
I got the question of what Checks means on the Jeep status page.
Basically it is a count of how many times my app has checked to see if the status of your Jeep has changed. The app checks every so often (more during peak hours for data changes) and tracks those checks to get the count.
Example. For my Jeep, the tracker has checked 9,001 times to see if the status has changed.
Jeep Wrangler JL Jeep Order Tracker - Open to Join checks
NDRugby
NDRugby
Northfiled
There were some connectivity issues this morning that caused some issues with the tracker sending email updates correctly. Looking to figure out what they were so I can recreate the emails. However, your tracking information on the site should be correct. Sorry for the incovenience all.
NDRugby
NDRugby
Northfiled
FYI. Last night I temporarily disabled the daily emails from Jeep Tracker while I work on some deliverability issues. The volume of email mixed with some ip related issues from my hosting provider was causing deliverability issues and rate limiting by multiple receiving services including Microsoft, gmail and others. This started to roll over into the deliverability of the Update emails.
So I figured the update emails are far more important, thus I disabled Daily to keep those running well. I'll let everyone know if it get it back up and running. In the mean time, in the next few days I am going to work on posting a daily update on your Jeep page itself, if I can make the layout work.
Any way, this is the message you will see on yoru page for now. Thanks all.
NDRugby
NDRugby
Northfiled
Some info on the tracker in case anyone cares. Here are the number of Jeeps in the tracker (minus those that turned the tracker off), that have reached each stage as of today. Pretty cool that it has tracked that many delivered Jeeps! Thank you all for joining. Fun to see all those Jeeps, even if it is painful for some along the way.
At it's peak, there were 872 Jeeps, not delivered, being tracked. That was in mid-October. Now it's down to about 714.
FX44AU
Alabama
2023 JLUR (on order)
@NDRugby have you seen any orders updated to D1 recently? My status data isn't showing any moving to D1 since last Friday. I'm sure there's a reason but it would be pretty cool to see how many total Jeeps are being tracked; not just the ones with common options.
Canada4xe
Robert
Vancouver
2023 Jeep Wrangler Rubicon 4xe
I’ve created my own Jeep Tracker for anyone with an order. A few people on here volunteered to help me test it and I think it’s pretty stable now. Thanks volunteers! Here are some details:
What Is It?
It’s an application I built to check the status of ordered Jeeps using publicly available data. The statuses it can check for are:
C- Order Confirmed
D1 - Scheduled
E - In Production
KZ - Built
KZM - Shipped
KZX - Delivered
As far as I can tell these are the only publicly available statuses. Your dealer can give you updates on other statuses like D or some of the other build and shipped statuses.
Here is a screenshot of my app (only my access, not visible by others)
How does it work?
It checks your VON and Last Name against data that is available on a regular increment (every 5-15 minutes). If there’s a change in your status, it emails you. Also if you’re at a stage where you should have a build sheet or window sticker, it will create links for you. I am adding code to check those and make sure they exist. Right now I’m assuming when they should be there. Here is a sample update email.
How is it different from the Pizza Tracker?
The data available is the same. But it checks for you. And in some cases it has updated before the Pizza Tracker. In other cases it updates at the same time.
What does it give me?
A Webpage where you can check your status without having to enter your VON and Last Name. You’ll have your own link. Looks like this:
Also, there is a daily update email (that you can turn off if you want) that tells you how many times it checked, how many changes it found and how many emails it sent you yesterday and all time. That looks like this:
Why did you build this?
I wanted a way to get updates on my Jeep without checking all the time and I like to build software.
I’m just a guy that loves Jeeps. I ordered a 23 to replace my 12. I built a similar system back then, but there was more data available. You could track every movement. I don’t work for Jeep and I don’t have any insight beyond what I show you.
How do I join?
Go to Jeep Tracker, click on Add Your Jeep to the Jeep Tracker. And then fill in your VON, Last Name, Email Address and choose whether you want the Daily Update email(you can edit this later).
It may take up to 5 minutes for your Jeep to register in my system. But that page will give you your custom URL to check status (you can also go to the home page and enter your von and last name to check status).
What else should I know?
I’m just opening this up now. So there could be errors or issues. Not sure how it will handle hundreds of Jeeps, but I’d love to find out. I’ll keep working to fix issues. So if you have a problem, please DM on here.
Good luck with your orders everyone and I hope you enjoy my Jeep Build Tracker.
I guess this only works for US orders?
