us3r1d
Interesting. I am not an expert.I'm glad you asked that question. Actually, I'm thinking NO! Here's why:
I haven't encountered FORM yet, but out of curiosity I have tried to run in the 200 degree oil temp range that it takes to clear it and it is _hard_ to get the oil up into that range.
175 is actually around the highest it gets unless I keep the RPMs artificially high, so good guess on that.
Maybe you could come up with a viable calculation using just RPMs after all.
Well, telling it you changed the oil is a 100% reset of the oil part of the FORM algorithm; since the whole point is to burn off fuel contaminating the oil, changing the oil restarts the whole thing from zero. So that's the expected behavior.Again, I'm not a 4xe person, but I thought I heard claim to some 4xe owners seeing the FOAM level improve in some situations when they told their vehicle (through the steering wheel controls) that they just performed an oil reset. Do you know if this is true or untrue? (If true, it would seem to point to Jeep actually using these same counters for their FOAM status calculations).
Of course, it logs that you've done that so you're probably playing dice with your warranty if you reset the oil life without having some receipts; the 4xe-specific forums have a few reports of Jeep denying warranty work for that.
