Drdyer9051
- Bradley
- Feb 1, 2022
- East Tennessee
- 4BT-Tj,Tj,4B-Comanche,2021JLUR,diesel 22JTR
BCM $A01A - OIL CHANGE STATISTICS
Here's another discovery that I wish I could claim credit for. You can determine how many engine revolutions, how many hours, and how many kilometers it's been since your last oil change. (Or since you've done an "oil change reset" on your dash.)
Ready?
# rid -d bcm A01A # Remember, -d is DECIMAL output
13 152 0 38 2 245
ENGINE REVOLUTIONS SINCE OIL CHANGE:
We take the first two numbers (in big-endian format) and multiply it by 1000. So...((13*256)+152)*1000 = 3,480,000 engine revs
HOURS SINCE OIL CHANGE:
We take the next two numbers (in big-endian format) to calculate the number of hours.(0*256)+38 = 38 hoursKILOMETERS SINCE OIL CHANGE:
We take the final two numbers (in big-endian format) to calculate the number of kilometers.(2*256)+245 = 757 kilometers (470 miles)
Enjoy!
And one very special thank-you to our benevolent anonymous patron for sharing this with us!
I was able to use your RID program (python3 rid.py -d bcm A01A) to get
51 5 0 163 26 209
so 13,061,000 revs
163 hours since oil change
6865 Km or 4265 miles since change
thanks,
so when I try to get Cabin Temperature from hvac at D01E
python3 rid.py -d hvac D01E
I get No response received within 2 seconds.
other modules work like tcm 1018 for Crankshaft Actual Torque it
returns 7 240
anyone able to get temperatures from the hvac module?
edit: I am looking into the problem of heater blowing super hot when controls are set to say 73 and it is below 40 degrees outside. I have to put it to low, let it blow cool air and then raise to 73...
this is a known problem and I would like to try to get a work around.
Second Edit: found problem.... hardware problem on can0
