Is this Rust Concerning?
WrangleredUp
New Jersey
‘25 JLUW XR (Joose)
I've had my New 2025 JLU Willys XR for about 9 months now, and after looking underneath recently, I discovered some rust starting to form mostly on the axles. I also noticed some corrosion on both the locking lug nuts and the protection ring screws on the Wheels. I can also see that the frame and suspension components are starting to look grey and slightly chalky.
Should I be concerned about any of this? if it's not anything to worry about than that's fine. If you have any tips to "fix" some of these issues, I would appreciate it. I have attached pictures of everything I mentioned. Thanks.
Jeep Wrangler JL Is this Rust Concerning? IMG_3796
Jeep Wrangler JL Is this Rust Concerning? IMG_3799
Jeep Wrangler JL Is this Rust Concerning? IMG_3798
Jeep Wrangler JL Is this Rust Concerning? IMG_3806
Jeep Wrangler JL Is this Rust Concerning? IMG_3805
Jeep Wrangler JL Is this Rust Concerning? IMG_3801
Nate88cool
Nate
NE Ohio
2023 JT Mojave, 2021 JLUR, 2016 JKU
Completely normal. If in the northern or salt belt have it oil sprayed and you're good to go.
dank8307
United States
2018 JL Sahara, 2016 KL Trailhawk, 2014 WK2 Limited
Not yet. Unfortunately, they're just going to keep growing and spreading.
Start spraying Surface Shield or Fluid Film every year. Properly done, that'll prevent new rust from forming and stop the existing ones from spreading. You'll need about 8 cans for the initial application to be thorough. After that you can cut it down to about 6 cans for subsequent applications.
WrangleredUp
WrangleredUp
New Jersey
‘25 JLUW XR (Joose)
Thanks! I’ve done some research on fluid film, and it seams like a big project for me to do myself right now. I found this place in Pennsylvania called Mount Zion Offroad and it seems like they do a pretty good job. They use fluid film black.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
Not at all a problem, or out of the ordinary, on those heavy components. You can spray some rust converter on it, then wire brush it. It doesn’t have to be clean bare metal, just the powder and flakes need to be gone.
Then dilute gloss black Rustoleum, from a can, with 10% acetone. The acetone will make it dry quicker and give it a satin finish. Use a small brush to apply it. Spray paint is messy, and causes ugly overspray when used for touch up work.
dank8307
United States
I used to use Fluid Film, but transitioned to Surface Shield because it's easier to apply and noticeably longer lasting than Fluid Film. Fluid Film is viscous and lasts for a year, whereas Surface Shield is less so (allowing it to creep into crevices better) and lasts for about 1.5 years. I still apply it every year. And I wouldn't call it a big project. You just need a couple of hours with eye protection, mask, and clothes you don't care about getting dirty.
Also, I personally don't like the black lanolin undercoating sprays. I tend to view people who use them on their vehicles as having something to hide.
WrangleredUp
WrangleredUp
New Jersey
‘25 JLUW XR (Joose)
A concern I have with these coatings is that I heard they could be pressure washed off. Does this mean I need to reapply every time I clean the undercarriage after off-roading?
dank8307
United States
Lanolin undercoatings are designed to resist being washed to an extent. They aren't going to be washed away easily if you spray them with cold water. Using pressure washer on the coated surface can wash them away a little faster, but not exponentially so. I use pressure washer to clean my undercarriage after wheeling and the coating stays on, as long as I don't use the pressure washer too close to the surface. The way these things work is they bead up and wick moisture away, so if there's even a thin layer of the stuff that's intact, that'll be enough to keep the water away from the surface.
They will, however, be washed away faster if you use warm water and soap.
Here's a video for demonstration:
AlgUSF
Melbourne, FL
2021 JLUS, 2014 Tundra, 2013 Odyssey, 2002 Civic
I only use AMSOIL products, do they make a similar product?
Jeep Wrangler JL Is this Rust Concerning? 1781903986018-83
Old Dogger
Cave Creek Arizona
Nope..........
dank8307
United States
Apparently they do. It's called the HD Metal Protector. They also have the regular Metal Protector, which is more of a penetrating oil than undercoating, so you want the HD if you want to try it out.
Jeep Wrangler JL Is this Rust Concerning? 1781905321205-n
I never used it so I can't say how well it performs. But this guy did a comparison test of various undercoating:
But, ultimately, after he had the chance to try to Surface Shield once it released, he went with Surface Shield over the others:
BRuby
Skiing or Snowboarding
JLUR Benz Porsche-M Subie-M
You have minimal rust. Just remove what rust you have and spray protect with CRC Marine. Our 2018 JLUR is used primarily to go to ski resort roads sprayed with brine. The only areas that need touch-ups are areas where rocks and road debris have removed the product. This product is awesome and requires almost zero maintenance over 8 years.
https://www.jlwranglerforums.com/forum/threads/jeep-jl-underbody-rust-prevention.81479/
Jeep Wrangler JL Is this Rust Concerning? IMG_7557
WrangleredUp
WrangleredUp
New Jersey
‘25 JLUW XR (Joose)
This sounds great! Will the CRC Marine give it any like new appearance aswell?
Reinen
2021 Jeep Wrangler JL Rubicon
It can be pressure washed off, by a very high power pressure washer at close distance (which will also remove paint). A pressure washer appropriate for washing a car is no problem.
I have a lot of exposure to salt. Our capitol city is named after it. We have a lake 8x saltier than the ocean. I drive on heavily salted roads during our 5 month winters and on the Bonneville Salt Flats in the summer. I have zero rust.
I apply Fluid Film in the spring and fall. It's really easy. Just grab a beer, lie on your back and scootch under the Jeep. Spray everything metal except the exhaust (it will just burn off). You'll be done by the time you finish the beer.
It does last. After 5 years and 10 applications of Fluid Film it was actually building up in places. So this spring I went under with a degreaser and removed all the Fluid Film buildup before applying a fresh coat.
This is 5 years in a heavy salt environment. You pretty much only see its age on the exhaust.
Jeep Wrangler JL Is this Rust Concerning? 1000013804
