Is this original?
ecidiego
San Diego
2021 Gladiator Mojave
Just left the auto parts store they tested battery and said it was ok so who the hell knows. The little screen said ok needs charge or something to that effect. I may go down the road and get a second opinion.
Charge it with a real AGM charger like a Ctek.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
It's 6 years old. Replace it. Easy decision.
The Last Cowboy
San Antonio, TX
If it dies in 2 years under warranty, where do you take it to get an immediate replacement?
Go to Batties Plus and get a re-labled Northstar or O'Reilly's or Napa to get a Deka.
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
Napa sells Odyssey and is currently 20% off, H7 should be around $270.
There’sOnlyOne
Greg
NW Georgia
2021 JLUR
H7 Ever Start at Walmart is $180 with 4yr warranty. Walmarts are everywhere. I've used the Ever Starts for many years and they last through the warranty. Local and usually in stock.
JLfromCA
JL
2019 Mojito! 2 Door Rubicon/2024 Sarge Green 392
Because you have E torque and if it’s still under warranty , I would take to the dealer and get it checked out. What if the 48V is killing the 12V. It’s a complicated system. If it all checks out you can still change the 12v on your own. get it documented at least. It’s in expensive gamble. 48V battery is 2K. Also it doesn’t have an alternator what if 12v battery is not getting charged properly. Lots going on.
Tyderian
Chandler, AZ
2018 JLU Sahara 2.0 Turbo
OP you do not have etorque. The secondary battery gives it away. etorque only uses the main battery for ESS, as I found out the hard way during my recent battery change. I also went with an Odyssey.
Gunfighter
P.J.
West Michigan
2021 Jeep Wrangler High Altitude
Trying not to get warning points
Battery could have been replaced before with an OEM battery...
Bandit59
Tennessee
2021 Jeep Wrangler 4xe
I did that. Got 3 different reading at 3 different places. But if you have a charger at home. U might get a few more miles from it. But most Mopar batteries have problems after 2-3 years. But I have a Ram that is 4 yrs old still going
gsbrockman
Greg
Sand Gap, KY
2023 Dodge Challenger Scat Pack Plus A8 & F8 Green
Owner / Operator Brockman Hauling, LLC
If you want another Deka that will last 5 years or more, go to O'Rielly's and get a Super Start (made by Deka) to replace it with.
Super Starts are my go-to battery choice for most all my vehicles, especially my past and current RAM / Cummins equipped trucks.
Just recently bought two for my 2022 RAM 5500 Cab & Chassis.
Gotta love buying’em two at a time.
Lots of O’Reilly Auto Parts stores around if an issue does arise.
Jeep Wrangler JL Is this original? IMG_9215
Jeep Wrangler JL Is this original? IMG_9218
Jeep Wrangler JL Is this original? IMG_9219
DaltonGang
Doesn't Play Well With Others
Almost 1 1/2 years on a Wal-Mart AGM battery. No issues.
Paluss
maryland
2022 JLURD
correct no eTorque in 2018
Zandcwhite
Zach
Patterson, ca
2019 jlur
That's the original. It's not a safety item. Nothing on your 2018 is covered under warranty anymore.
That lasted a good long time. It was a pre-covid installed battery made by Deka, a quality unit. A new Mopar battery isn't near as good. If you want another Deka that will last 5 years or more, go to O'Rielly's and get a Super Start (made by Deka) to replace it with.
The emissions warranty, which includes the etorque system and 48v battery is covered by an 8 year/80k mile warranty so depending on mileage would still be covered but you are correct about the 12v battery.
