Is battery IBS needed?
DieselDog
Montana
2020 JLURD
A few months ago I did the aux battery delete while my ECU was out and being worked on. Since the ECU was gone for a month, when I connected everything back up I had kind of forgotten about the IBS and although I had it connected to the battery, the electrical wire plug connection for it was undone. I thought it weird for this vehicle that my alternator was putting out a pretty constant 14.9v. Then, twice while pulling a long hill on the highway, I got a check engine light and a code for turbo van actuator (ecodiesel). I started monitoring my turbo vane commanded vs actual position, and they were always within 1% of each other and moving around as they should be. While investigating under the hood, I found the disconnected IBS and plugged it back in. I have not had a check engine light since then. A.I. confirmed that without the IBS the vane actuator could have been receiving voltages that were out of the norm and easily caused the CEL.
TheRealChad
TheRealChad
Chad
Los Angeles
2021 Rubi 4xe
Cleaner visually? You could fabricate an abs cover to hide the battery and wiring if you just want a visually simpler engine bay like on a street rod.
You have me interested … but I’m not sure I’ve ever seen one. Got a pic?
Terrymo
Terry
2023 JLURXR 3.6 ET
I’m guessing it would have to be fabricated. Sorry. No pic. Just brain storming.
THAW
Foster
23 JL4DrRubicon
IBS SOC is used for all sorts of BCM things (e.g. disabling ESS and AUX Switches). Presumably null SOC data will create many (perhaps minor) issues.
TrailMax
Max
Arkansas
2023 Wrangler High Altitude 4xe
But does it help anything? I do not have the aux battery (2023 392), but do have a lithium battery. Without it I can ditch that oem terminal post attachment and go to a cleaner solution. I suspect it would also keep the state of charge full right?
Instead of adding a post to use the OEM terminal, would you be able to mount it to one of the 'spare' terminals on the Kaas terminal block?
